C
Carla
I really need advice. I know nothing about electrics so i am looking for someone to give me some basic answers and help.
I want to put lighting around my ceiling. I need 20meters, I found 20 meters of led strip lights on ebay, they come in 4 rolls of 5 meters totaling 20 meters.
It says the specs are 12v 10a and 120watts (please see attached photo) I have tried asking the seller for advice but he isnt making much sense.
basically i need to know if the 10a power supply is enough to power 120watts (20meters) of led lights? im worried about it not being enough and they might over heat. im assuming it must be ok otherwise they wouldn't sell the power supply with the 20m set but i just need to make sure it is suffice to power it.
Hi Carla,
Welcome to the forums.
On the face of it, it appears that the power supply should be sufficient. However, buying from eBay, particularly if the seller is in China for example, can be a risk... particularly with electrical goods.
Looking at the picture you have supplied, the power supply MUST be in a suitable enclosure as it has exposed live connections. The connector used to connect it to the LED tape will also be of limited use in your application as you are wanting to go around the perimeter of the room whilst the connector supplied requires you to put the tapes all starting at roughly the same place (within the confines of that connector). I wouldn't want to run four of those connected in series as I suspect the voltage drop would be quite substantial, resulting in varying levels of intensity along the length of the run.
Just my initial thoughts based on the limited information.
Hope that helps.
Hi Carla,
Hope that helps.
so that silver power supply you are sayimg isn't enclosed properly? my guy doing the job says i need 15m in living room but told me to get 20m roll.
you say the power supply is sufficient but you said they will have different levels of intensity. which i dont understand. what would you suggest i do to ovoid that
Nor would anyone else who knew what they were doing. Each strip would only get 3v if they were in series.
  • Disagree
Reactions: curly
Actually what I was getting at was connected end to end.
These RGB tapes are typically 3 bus bars (or 4 if they have dedicated white elements to the LED chips) plus ground, and they can be connected end to end. But the voltage drop in the tape would be quite substantial on a run that long.
they wont be joined end to end as i have an opening to another room so both ends wont jojn. will this effect the light intensity
Agree with SparkyChick. Buy from a reputable dealer, not ebay. They will make up your strips to size and pair them up with the appropriate driver etc. There's loads of retailers.
i dont really have the time as i need them by next week. so need to order by tomorrow. i really just want to know what i was asking about in my last post
if you are asking how to do the job you have came to the wrong place
IMO get a spark in to advise you what you require.
and pay him to supply and fit .agree with madam chick .
Reactions: spark 68
buzz, calling SC "madam" might well result in a well placed kick to your goolies.
Perhaps he was calling her "madman chick" but got the spelling wrong.:D
Place I ordered from came within 4 days, including them making up bespoke lengths.
Perhaps Madame would be politer
Wot about Ma'am, an address for Royalty or a senior officer :)
mademoiselle is more appropriate. i don'think she's married. :D:D:D.
Reactions: SparkyChick
... just don't capitulate to the feminists and use Ms. I HATE that!
I'll call anyone, what they want to be called.
I knew a bloke once, who called himself Richard Cohead, we called him Dick & his last name was spelt Cockhead. What were his parents thinking?
  • Funny
I'm spoken for so that's me out of the frame then, can't stand change and after 48 years what use would I be?:mad::D:tongue::praying::ambulance:
Getting back on topic a mate of mine disregarded my advise not to go with Chinese downlights from fleabay because he was too tight to pay the £300 quid odd for the Collingwood units I wanted to supply....they all failed within a year. Cost him a lot more than £300 quid in the end.
Reactions: Marvo and DPG
I'm with @SparkyChick posts. You pay your money you take your chance. You have to be careful with Chinese electrical goods.
Go with @Midwest advice and get them from a reputable dealer.
  • Funny
Reactions: Midwest
If somebody is doing the job for you and you are unsure what to order, get him to supply the lights.
Maplin are no longer. B&Q possibly yes. Also either the Range or Home Bargains sell them I think.
If you go to Eyre and Ellison in Chesterfield, you can walk out with them, they use PowerLED components, so far very good.
its the RGBW ones I'm looking to get as the white on them is pure unlike the tinted white on regular RGB led strips
i doubt the range would sell 20 meters of RGBW as its quite a big strip. i live in essex but i could give the one in Chesterfield a ring, maybe it can be done over the phone and posted. thanks guys
if i used a different electrician would they generally get them from a reputable supplier or would most use chinese products? i could tell an electrician i want them from a reputable supplier but id have no way of knowing if they would actually do that or not
my electrician wanted to buy them from china. id like to get them myself from a reputable supplier but i dont know where. would it be somewhere like maplin or b&q ?
Goggle is your friend there, just avoid ebay. Simples.
Being on the end of things that have gone Pete Tong, its far simpler to deal with a UK based retailer.
Eyre and elliston have a branch over the border at enfield and Edmonsons have one near Romford. Strips come in 5M rolls, give them a call for 4 rolls, probably two drivers and two controllers. You can get some tech support from them, to a limit , 20M at 12V is not something i have contemplated, in fact, you should be looking at 24V and get the supplier to match the strip length to the driver.
so if i got 4 rolls of 5 meters, i could attach them all together and cover the 20m room. does that mean at each point where i connect another 5 lm strip i would have to have an adapter n cord running down the wall? i planed to have the cable n adapter run down the corner of the walls and box it in to hide it
I really need advice from an electrician ASAP. please help me? Im so confused
Carla,
Baddegg,
