May 27, 2018
60
helston
Hi all
I'm after a bit of advice I've recently purchased a house with a PV Array which was installed in 2015 and I have a copy of the MCS certificate.
it is owned by me outright without any FIT connected to it.
How can i maximise the utilisation of the electricity it generates as I really don't want to be exporting electricity to the Grid needlessly if possible.
Thanks in anticipation
How big is the system, you can get that information from the MCS Certificate? Why wasn't it registered for FiT, are you sure it isn't? Is there a generation meter?
Water heating is always a good way of soaking up "excess" electricity...
...until the water boils of course. :D
atoms from the grid will only come one way and not the other way ,why do people think they are put electricity to the grid .unless they have one power station .
Hi
Just dug out my MCS certificate to answer the above
Installed capacity 4.0kw commissioned 06/08/15
there is a generation meter
and no i don't have any batteries
as was determined by my solicitor during the purchase there is no FIT agreement
and ok then if I'm not exporting it - I want to stop wasting the potential generated
I have a system similar to yours although I get a fair whack from the FIT, I have a solar iboost and during the Summer if sunny the solar heats my water, we tend to leave the dishwasher and washing machine to run during the day if sunny etc etc. My solar iboost lets me know when I am in credit and have an excess to use.
Atoms don't go anywhere.
Only electrons do.
To put electricity into the grid simply regulate the output of the inverter to be slightly higher than the incoming grid voltage.
Simples!
It seems odd that someone would instal a PV system and then not avail themselves of the income available from the FiT scheme.
Considering this some ....you should be able to apply to one of the many suppliers who offer FiT connections and receive the appropriate level of FiT income for the system you now own.
I've been away from the PV game for some time, so others who are more current with scheme terms might have things to add on the subject.
I would be staggered if this systemn was not registered for FITs. Would contact the vendor of the house via your solicitor. The FIT is for the system and should have been transferred as part of the sale of the property. As you have an MCS certificate this would suggest this to be the case. If by some outside chance the system is not registered, there may still be time as I beleive there is up to 12 months from the end of the qualification period (31st March) to do so. However, a FIT from 2015 will be worth a whole lot more. Ofgem also have a central FITs register and may be able to help.
To maxx out self consumption:
Change behaviours - put the washing machine/dishwaher on when you go out to work, not when you go to bed. Think about when and how you use electrcity, then do all you can to coencide with PV production.
If you have a hot water tank, fit a diverter to send excess to heat water via the immersion element. Be aware you only save the cost of whatever you use to heat water.
Look at battery storage. Do not go for a cheap and cheerful system. There is a lot coming in terms of utilising time-of-use tariffs, weather compensation and other cleverness to not only maximise use of PV generation but also to charge/discharge using the grid to avoid buying peak rate power.
Use a solar optimised car charger to charge your EV from your PV.
helston
Purchased a house with PV
Tags Tags
house
JanCDav,
The Solar King,
