H
HoneycombEchoRomeo
Hi Guys,
I have seen this in a loft and wondering if it is legal, the junction box is open of course.
also one cable (1.5mm flex connects to a 3amp labelled FCU to an extension lead).
it seemed the cables weren't able to fit as it was jam packed and someone added some wagos ontop.
Can i keep it like this or would this need to be rectified.
The added Wagos aren't necessarily a problem, but the missing cover, unsecured cables and damage to the sides of the enclosure most definitely are.
Reactions: Dartlec
i took it off as i was wondering whether or not i can add to it. Did not even notice the damage on the left side till you mentioned them thanks! any recommendation on a wago box so i can sort this out? I just like wago they seem easy but they dont seem to have a box that would fit all this.
It looks like you may be able to get all those cables into a Wagobox XL
ae235
That will take up to 12 individual lighting cables.
rip itn out, start from scratch wago XL box as suggesrted,
The original connector block JB looks like it was quite neat and tidy , but who ever made the later alterations using the wagos made a bit of an untidy mess
If it were my house (like a few others have said) I would re-do the JB in all wagos in a big wago box
Junction box in loft with added wagos to extend lighting.
HoneycombEchoRomeo,
Dustydazzler,
