- Sep 19, 2024
- 12
- 0
- 1
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hi all,
I have a hybrid car and I’m trying to install a socket outdoors. I’m on E7 and have storage heaters on their own circuits, can I make a little T junction within a back box like so and connect that round the corner to an external EV-rated socket? Circuit is 16A, storage heater does not get used, and the socket has RCBO protection. The switch is for the storage heater, cable from CU runs vertically down and powers only the storage heater.
Thanks in advance,
Rob
Thanks in advance,
Rob
- TL;DR
- Spur from heater circuit for EV socket
