E
Eco Deal
It must of been lower than that noshocks because I register at around the 1200 and you was MCS before us
And the firms that actually survey jobs correctly will be up against the crash, bang wallopers (buy a 4kWp kit, give the panels to the roofers, get an electrician to plug it - forget calcs, forget shading, forget everything)
Same level of work..WHERE..EPC will kill that level to about 40% me thinks...40% is me being an optimist...
I guess it does depend on a lot of other stuff as well like loft insulation, condensing gas boiler, heating controls, thermostatic rad valves, double glazing, low energy lighting etc etc. so D would certainly be possible for a solid wall house, particularly once you add PV into the mix.
I may be wrong, but I understood it that the points per item actually changes depending on other items. So in the house with the solid walls it would gain more points for having a condensing gas boiler than a house with cavity wall insulation would gain from having a condensing gas boiler, because the heat demand would be higher so there would be more direct gains from the more efficient boiler... etc.
At least I'm sure that's what our EPC guy was saying.
