- Reaction score
- 42
Hi All
I would appreciate your help with the following.
I am familiar with standard calculations such as calculating the current draw on a three phase heater battery when the loads are balanced across the three phases. I have recently come across some equipment where it appears the heater battery has been deliberately designed with a load imbalance. I believe this is to enable the manufacturer to use their standard elements to produce alternate heat outputs for special purposes.
The heater is as follows:
2 off 21 Ohm heaters and 1 off 27 Ohm heater wired to a 400V 3 phase supply in star formation with floating centre point.
Now I know that 3 off 21 Ohm heaters wired this way would result in about 10.9A/ph and 7.5kW heat
and 3 off 27 Ohm heaters wired this way would result in about 8.7A/ph and 6kW heat
How would I calculate the current draw and heat output of the hybrid heater battery?
Any help appreciated
