Discuss AC fan stays on at all times? in the Auto Electrician Forum area at ElectriciansForums.net
C
Caleb Mueller
Hello, I have a 1988 Toyota Celica Alltrac (4WD Turbo) and ever since I've owned the car, the front secondary fan (mounted on the front of the radiator and blows into the engine bay) stays on all the time at low speed when the key is turned to the start position (engine off and engine on). Also today my radiator fan 30 amp fuse blew and my car overheated. I replaced the fuse with my 60 amp anti-lock brakes fuse to get it home and it didn't overheat. We have checked all the relays and they seem to be working fine. What is going on??
most common cause of a fan running when it should not is a shorted out temp sensor, usually mounted on the rad. check it with a ohm meter. should read open circuit when cold.
It could be a temp sensor or maybe a pressure sensor on the high side of the system. Either way test them as Tel suggests and look carefully at the wiring to see if someone has deliberately shorted the sensor as a temporary repair in the past.
Could also be that the fan relay contacts have welded together with age.
Really difficult to tell without actually having the car in front of you.
The best place to start is the Toyota technical information unless you are not experienced in diagnostics!
Your post suggests that there maybe two electrical fans fitted, one for the A/C system and one for the cooling system, and when the A/C system fan is not operating the cooling system overheats!
Your post comes across to me like you have more than one problem. If you intend trying to resolve the problem(s) yourself, have you got any diagnostic equipment to carryout an investigation, can you check and read fault code data!
Can you read live data!
Difficult to steer you in the correct direction without more detailed information!
Reply to AC fan stays on at all times? in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
The symptoms its been having to start with was the fuel gage only working sometimes and when i play music from my phone when a loud song came on...
B
Hi, I just purchased a 12V 10" electric fan from Supercheap. Brand is Calibre Calibre Thermo Fan - 12 Volt, 10" - Supercheap Auto Australia...
6K
N
Hey guys, My Radiator fan (cooling fan No.1) is not getting any supply (12V from the car loom, female connector) when the water temp senor is...
4K
nytrus90
N
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
