Discuss Advanced Electronics MX4100 Fire Alarm network in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, I now this would be best in the fire alarm forum but I don't have access.
Does anyone know what cable should be used to network a planet and remote terminal. We're doing the first fix for the fire alarm and the drawing says 2xFP200 1.5 t&e. The installer guide doesn't specify but mentions twisted pair. I would have expected it to be a belden.
For a repeater it must be fire rated cable so in this case would be FP200. If im not mistaken Tazz will pull me up on it - however im pretty sure.
Cheers, makes sense, fire rating for comms otherwise you'll be repeating nothing!
The job is about to be plastered and decorated, it would be a shame havering to add something surface just if the designer missed something.
The cable must be fire proof FP200 2 core+E 1.5mm One FP200 cable for 24 supply, and one FP200 cable for data.....Important note, do not use 4 core FP400. This may corrupt data, and the repeater will not work.
Reply to Advanced Electronics MX4100 Fire Alarm network in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
S
Hello all I'm new to this forum and have recently joined due to a lot of threads here have been quite interesting and many have very good answers...
4K
Sam cook
S
S
Hi Guys, I've been looking for an alarm for my work van that will chirp out an audible alarm if someone walks up to it. I want to prevent...
StopCox
S
H
I'm wanting to add a couple of sockets in my caravan as there's only 2 at the minute. Not something I've ever worked on before, I'm going to have...
Hi, I've just moved into a 1900 house with an existing home alarm. It says on the box that it's a Gemini Advanced Microprocessor Control. I don't...
Hi All, Just had a discussion with one of the local fire officers in our area regarding one of the hotels we look after. He told me that when we...
Deleted member 26818
