If you wire the portion between mcb and say half way but leave the remain half untouched is this new , half new , existing ?
Alteration to an existing circuit.
That’s is exactly 100% what I would say.
But Just playing devils advocate for a sec
If you went back say 3 months later and replaced the remaining half would this be another completely different alteration or would this now new be a ‘new’ circuit ?
Reactions: Spoon
I fear the answer is back to the triggers broom conundrum
egggackly.my dad's axehas had 3 new heads AN 2 HANDLES, BUT IT'S STILL THE SAME LOG PILE.
and why does the caps lcok be next to the "A". why not put it by the "q"?
  • Funny
Reactions: Jim_e_Jib
If you are talking about the dreaded Partpee , then no your job doesn't sound like it falls under 'notification'
It does still however need to comply with current building and wiring regs , but does not need to be scam notified
OP shows his location as Dundee, which I believe is north of the border, so they do things rather differently up there. Not sure, but doubt if he needs a warrant, or whatever it is.
Garage Conversion Certification Advice
ATD,
Midwest,
