- Reaction score
- 6,671
Didn’t want any tea or coffee.
Iain, they can't have been real electricians !!!!
Discuss Is this installation considered acceptable today? (1-ring including oven and everything else) in the UK Electrical Forum area at ElectriciansForums.net
Good to know, so that signal is not going to be even close to WiFi - and longer range which makes sense for safety devices.
I found the WiFi to be dire even before the CCTV got added in, but it definitely adds strain to it!
The solution I came to was to put an AP in the lounge and an AP in the master bedroom, pretty much opposite ends of the house, and it works pretty well.
If I continue to have issue, may split the network for the CCTV and the rest, but I'm in the process of running 12x CAT6 to each room so the WiFi really is non critical for anything intensive by the time I'm done.
Edit: total visit time was around 40 minutes.
In my view that is commercial scale use of a domestic supply "technicalities" aside, to put it another way it is not normal domestic use of a system designed for exclusively domestic use. If I were a landlord and the system was overloaded by your use I would be looking to you for reparations. The onus would be on you to rebutt the claim. But as has been stated it is highly unlikely you would overload the system anyway. Bear in mind there have been tenants before you and evidently there has not been a problem, if there is in your particular case it may be that you are using the system in a non normal way.
12 CAT5 points in every rooom - bit of an over kill ...
Bitcoin mining?
40 minutes is a bit quick... even though theres 2 of them, and the number of circuits in the CU is quite small.... they must be really experienced in doing EICR's that they can do them in such a quick time.
So its proved there is, and has always been only 1 ring final circuit here for all the sockets in the house.
So what is it with all the IT equipment? Either large scale pirate bluray copying going on or editing of some rather "specialist" films?
So no dodgy videos, then?
The truth is coming out now dodgy dvd'sNowt you can't find on Google
Did once look at setting up a cam girl business with a friend of mine, but neither of our mrs' were having it!
Did you ask them to be performers?Nowt you can't find on Google
Perhaps why there is only mention of a daughter now!
Reply to Is this installation considered acceptable today? (1-ring including oven and everything else) in the UK Electrical Forum area at ElectriciansForums.net
