Tony Way
75
42
93
Cambridgshire
United Kingdom
Had a call from a mate saying that he was going through 1361 fuses regularly. Haven't seen the job yet, but asked some basic questions about fittings and evidence of shorting etc. He says no.
It might sound stupid, but my understanding is that 1361's blow when an exsessive curent is demanded usually by a dead short between L/N. If it were a fitting, it would show signs of damage etc.
As it is an intermittent fault, My bet would be on the cable or a hidden transformer of kitchen lights (he thinks the kitchen has 12v downlighters).
My approcah would be isolate transformers, pull lamps and insulation resistance test.
Any other suggestions?
could be an intermittent short circuit antwhere, on the wiring, in a fitting. orrr...... has he had extra lighting fitted, too much load?
change to PUSH IN 60898 MCB 6A as they are easier to reset and that extra capacity may help!
also IR check circuit to check for low resistance!
i've got some of the posh ones, flip switches no less!!
Thanks guys
I think I'll be spending some time hunting this one down.
Tony Way
Cambridgshire
United Kingdom
Lighting circuit continually blowing 1361 5A fuses
Australia
Tony Way,
Tony Way,
