Top Bar
Install 1x new 63amp SP sub-main to cupboard in top bar:
40m of 16mm 3core SWA cable to run from main intake to cupboard in top bar- above false ceiling
Install 1x metal SP 10way consumer unit in top bar cupboard- with RCBO’s
Rewire lighting and power in top bar- wiring to be above false wiring- supported by ‘all round bands’
Wiring to be dropped to existing socket positions through existing conduits
Circuits to be supplied by new consumer unit in top bar cupboard
Supply and fit 20 600x600mm 40watt LED panel lights in cool white
-to be on 1gang switch either end of top bar (2way)
Supply and fit 6x 50watt LED floodlights for dart boards
-to be controlled by 1x 2gang switch (1way) (3 lights on 1 switch, 3 lights on 2nd switch)
Supply and fit 10x white plastic d.sockets (installing 1x addition d.socket behind slot machines)
Re-supply 10x existing emergency lights- fittings not to be replaced
Main Entrance Lobby
Rewire lighting and power in lobby- wiring to be above false wiring- supported by ‘all round bands’
Supply and fit 4 600x600mm 40watt LED panel lights in cool white
-to be on 1gang switch (1way) inside front door
Supply and fit 2x white plastic d.sockets
Re-supply 3x existing emergency lights- fittings not to be replaced
Snooker Room
Rewire lighting and power in snooker room- wiring to be above false wiring- supported by ‘all round bands’
Circuits to be supplied by new consumer unit in main intake
Supply and fit 4 1200x600mm 65watt LED panel lights in cool white
-to be on 2gang switch (1way) (2 lights on 1 switch, 2 lights on 2nd switch)
Re-supply existing emergency lights- fittings not to be replaced
Re-supply 2x existing AC units- fittings not to be replaced
Re-supply 2x existing money boxes- fittings not to be replaced
Re-supply 2x existing hanging table lights- fittings not to be replaced
Never really priced for anything outside of domestic before so bit daunted!
I am thinking 5500 with for 2men?
Main Entrance Lobby
Snooker Room
