J
Jackson Greaves
Cool, thanks guys!
Would the fuses terminal blocks here be suitable for putting inline fuses in for the PSU and monitor?
Plug Top 20mm and 25mm (1 Inch) Fused Terminal Block | maplin - https://www.maplin.co.uk/p/plug-top-20mm-and-25mm-1-inch-fused-terminal-block-tz17t
However, I was thinking, this monitor is just a 19" Dell LCD pc monitor. Usually the kettle lead plus straight in the back so I guess it has an internal fuse no? If so do I still need to fuse the live line in for the monitor? Or just the PSU?
