Unfortunately the BC officer is god in this situation. I would stop worrying and as Trev says, just bung em in.
11.50 each for two aico ionising mains alarms, a few metres of 3 core and earth, and an hour or two.
taking the inspector on will end in the same result as suggested above
Should that not be 1 ionisation and 1 optical alarm?
Is this written in black and white anywhere?
Considering the subject matter of part p it's not exactly a huge leap of faith to work out what a refurbishment of a domestic installation would constitute is it?
If the rewire is finished and all floors down etc then use aico relay base smokes, you can just add the 2 smokes and heat near lights with feeds in and feed them that way, then code the bases so they interlink via a radio frequency, okay they are around 40 quid each instead of the 12 they would cost if normal mains detectors purchaed but no wiring between detectors and 3 hours work max to fit the lot and no mess or making good.
Mike
Reactions: 3 people
Building document B & fire safety 2000 covers installation of fire detection within dwellings.
This only requests, new builds or alterations, such as extentions, and loft conversions. As the alterations would be covered by building control, detection would be compulsory. As to the building in question, the op has not altered the construction of the building, only rewired it. Therefore detection can only be recommended from a safety point of view. Therefore the only person to make this decision, is the person who owns the property.
I have just completed a complete rewire on an average 1960's 3 bed semi.
Inspector chap has just been round and said to get signed off I need to install 2 smoke alarms and one heat alarm in the kitchen, because there is no door, and they all need to be interlinked.
He couldn't quote me the appropriate regulation or law and I wasn't going to press the point as some people make bad enemies!
I have spent an hour trawling through 17th regs, OSG, Part P, and Part B. I cannot find any reference that says you HAVE to do it.
- Customer is more than happy with two new battery powered smoke alarms.
- There were NO smoke alarms at all when I started.
- There is no other building work being done. Just the rewire.
- I know what the inspector says is best practice.
- It's not a massive amount of work.
- The customer just does not want the expense!
- It is usually best to KNOW what the requirements are!
Can someone please tell me:
A) Does such a regulation/law exist?
B) What is the reference number/page number/document reference/title?
C) What the local building inspector asks for he gets.
If the inspector is involved because of "material" alterations to the fabric of the building they WILL want smokes added before they will issue a completion notice.
Learn and move on!
Murdoch....from what can tell this is just a scam inspector, not building control.
OK but its a rewire and as the OP hasn't actually confirmed who the inspector was and whether other works are being done, we as usual, are pxssing in the wind.
EDIT: If he's not a scam member and has paid LABC then the inspector may well apply "local" rules and insist on the smokes.
True..reading between the lines, most building control inspectors are pretty clued up, and present all documentation and regs in writing along with layout drawings....the op sounds like he been given nothing...hence my conclusion it just a scam inspection.
Interestingly I'm working on a refurb at the moment of a bungalow. BC are involved due the material changes to the structure.
BC man insisted on fan in cloakroom (no window) but didn't specify smokes were necessary! I persuaded the client to include them!
Woking BC are normally shxt hot on smokes being fitted - so maybe a bungalow has different rules??
Its still a dwelling, if any area has been opened up from the circulation area, extension etc, bc will go down the smoke route, if no new rooms, then they leave it down to owner....to be honest I think bc play a fair game
Thanks for the posts. I appreciate the varying points of view.
Whatever the law is or isn't the general opinion looks like just do as LABC requires.
I was going to anyway but it doesn't hurt to air stuff here.
Thanks again. Your help is appreciated.
So who was the inspector?
Local registered tradesman who checks my work out as I am just starting out and haven't got myself registered yet. That's the next hoop to jump through.
Qualified. Increasing my experience all the time. All the work gets checked and signed off.
So a nobody then who doesn't know the rules. Get yourself a decent mentor
Reactions: 3 people
If I have sufficent floor boards up I offer to put them in just for the cost of the materials, never done a rewire without them!
Hang fire, why have building control been notified of the rewire and coming out to check it? Am I missing something here... Presumably there's other building work going on?
I always fit smokes, I build it into the price and tell them you either have it or find someone else.
Funnily enough I've got 4 optical and one heat to install next week for someone, all wireless aico.
Smoke alarms - Complete rewire - Cannot find any regulations/law
uxb443,
telectrix,
