Discuss Armour cable ran to garage on 16a breaker in the DIY Electrical Advice area at ElectriciansForums.net
Dazza123
Hi Everyone,
I have armour cable running from my house to my garage in a new build, it is connected to 2.5 that connects to my consumer unit, can i put a socket before armour cable for my wifes new battery hoover without any adverse effects? its protected by a 16a breaker then runs to garage on armour to garage unit?
Thanks for all your help
Daz
So you have 16a mcb, 2.5mm cable to I presume an enclosure somewhere that connects it to an armoured cable?
Assuming you terminate and connect efficiently only adverse effect will be loading issue
if it's a battery hoover, is it protected by the relevant legislation? i.e. does it have enough room to turn around/sit/lie. is it's cage kept warm and clean? are it's animal rights being adhered to?
Hi Kate, Thanks for your info, To answer your? yes the 2.5 is connected via terminal strip, just going to put socket in the middle and re connect a new 2.5 to armour cable, there is only 1 socket and one light running in garage so no issue then?
Thanks:1:
load wise, no. as your 2.5mm cable will take a load up to 26A and is protected @16A, only problem would be if your connections were not sound and you had problems there.
but i thought my post #3 had more thought put in.
Reply to Armour cable ran to garage on 16a breaker in the DIY Electrical Advice area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
