Discuss Can someone answer this? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
ian.settle1
Mentor
On my way home every night I pass a house in the countryside which has a wind turbine in the garden which stands approx 30 feet high, I was just wondering if anyone could tell me if this wind turbine's output is AC or DC?
Did you used to work on the fairground rides by any chance :wink5:
no, but we had a useful lamp post next to the front window.
- - - Updated - - -
b&q used to do a 2kW jobby. installed for £1800/
:) first thing google showed up...!!
it will be a ssimilar set up though as you say with rectifiers, invertors and phase sync..
Yep, that's why I plumped for DC for a smaller model. I've not seen any standalone AC->AC phase sync tech for grid hook up.
Maybe they're AC and probably supply a battery charger for deep cycle batts via a charger?
try knocking the door mate and ask the occupier if you show your interest they may show you how its configured
Reply to Can someone answer this? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Good Afternoon All, So I have a new situation to me that I cannot seem to get a definitive answer for. I trained as an electrician and did...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
