Thanks all, that's what I was hoping that I could replace the obsolete item so plan to whip out the ELT and replace RCD, which is an improvement on existing and perhaps advise that the old setup is not in accordance with regs having an rcd for main switch, but is now safe? I'll just note this on the MW cert under existing installation. I'm sure I won't get the job anyway, I find the hardest part of the job is quoting for a small job which others would do quickly and cheaply ignoring the existing installation. I know she has had quotes around £50 for an additional socket, and I've quoted for missing gas bond top floor flat and new rcd, remove ELT, so struggle to do it under £100. So it'll be another unsafe mod by someone. I know we can't cut corners to get the job but it would be good if we were all singing from the same song sheet. Thanks for your advice re rcd.
