Discuss Non-Electrician Need Safety Advice in the UK Electrical Forum area at ElectriciansForums.net
TATA
Hi. Yesterday I got electrocuted when getting out of one of those inflatable Lay-Z Spas and had to go to hospital. I am fine, thank goodness, but I am now trying to address this with Bestway who manufacture these products. They asked me to take photos of the set up I had (plugged directly in to a mains socket, as they advise) and said that they will need to test the socket, so it got me thinking...I fed the lead in to my kitchen and plugged it in to one of the sockets there and there was no indication of voltage in the water when I used my voltstick. When I plugged it back in to my conservatory socket where it had always been however, the voltstick lit up! I have recently moved in to my house and now that I have been here a few months I have started to realise that the painter/decorator who lived here before fancied himself as a bit of a jack-of-all-trades. I think he built the conservatory himself and now also think he wired it himself, as that socket causes my spa water to be electrified!
Where I am more confused though, is that Bestway state that their spas have built-in RCDs that will cut power in the event that water becomes electrified and also if there is some sort of power fault. So even though I seem to have a faulty socket, should the RCD still have prevented the water electrocuting me? I just wanted some professional advice before taking this further, as I can see them trying to use the socket fault as a way to wriggle out of responsibility, or maybe they would be justified in doing so? I just have no idea - any insight is greatly appreciated.
UPDATE: They have sent me an email with the following:
"All of our Lay-Z-Spa comes with an RCD either built into the pump, the cable or the plug which is a safety device which is designed to prevent you from getting a harmful electric shock. You can read more about RCDs at this link. The RCD that we use in our spas is very sensitive – 10 mA cut out which eliminates the risk of a harmful electric shock.
For Lay-Z-Spas made in 2016 and 2017 the pump includes a grounding system, which is double insulated and links all of the electrical parts of the pump directly to the grounding of the electrical system of the house (known as a class I electrical product). The spa therefore relies on the earthing arrangements that you have in the property (and the electrical socket you are using) are up to the required standard.
We would like to arrange to send you a plug-in socket tester. This will provide some indication on the status of the plug being used."
hi, i have a similar spa. it has a RCD built into the lead. if you look, about a few inches from the plug ( the main one, not the elv for the lights) there's a big black lump. it's a 10mA RCD. with the lead plugged in ( to your kitchen) press the test button on the lump. it should trip. in theory, this RCD should prevent any shock levels that could cause injury. however, my take would be that you have fauly wiring in the conservatory, and you 1st call should be to get an electrician to investigate. whereabouts are you. 1 of us may be close.
Bearing in mind your comments about the electrical wiring in the house, I would get an electrician in to some testing using appropriate equipment. It does sound like something is amiss, and the shock you have already had proves that this testing needs to be done urgently.
Thanks for the fast replies. I am especially keen on the Mother-in-Law suggestion! I unscrewed the faceplate and this is what I saw. There is an earth connected to the socket by the looks of it, but then another loose earth on the left - does that suggest that what they are saying about relying on the property's earthing means it isn't their fault?
Looks like short wire is the flylead which connects the metal back box to the earth on the face plate. Does it look like it's been cut? I only ask as it looks a bit short.
You still need to get an electrician in to do some testing though.
the fly lead to the back box was once obligatory, but now optional. should not affect safety. the problem may be upstream of that socket. as requested previous post you location.
edit: and although a voltstick is a useful tool , used correctly, it is only a rough guide and should not be relied upon where safety is paramount. ( in short, give it to a plumber to play with. make sure he wets it before use)
Do not rely on that voltstick as a method of indicating, well, anything really.
Any electrical work should be carried out with a two probe voltage tester, and some knowledge of how to use it.
PS
No you didn't. Not unless there is an internet connection in the after-life!
Reply to Non-Electrician Need Safety Advice in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
