Discuss Twin and Earth 2.5mm - From tool station in the DIY Electrical Advice area at ElectriciansForums.net
M
mds1256
Hi all
I was in need of some 2.5mm twin and earth for a spur, was passing tool station and called in.
Got Twin & Earth Cable (6242Y) Grey 2.5mm2 x 25m -
But when looking at the cable its got written on it: 2.5mm + 1.5mm.
So it looks like the live and neutral is 2.5mm but the earth is 1.5mm?
Is this still ok to use as I though all cable cores had to be 2.5mm?
Thanks in advance
This is a standard cable construction, the earth only has to withstand a fault current long enough to operate the protective device which is in a fraction of a second.. the L/N cores carry the working energy of the circuit.
Its saves on copper hence cost so yes the correct cable.
Reply to Twin and Earth 2.5mm - From tool station in the DIY Electrical Advice area at ElectriciansForums.net
Correctly closing off a dead twin and earth cable in a loft. My old house used to have radial circuits serving night storage heaters. Those...
Hello, I am renovating a house. I am rewiring myself. I am getting an electrician to install a new consumer unit & test all my work. I'm looking...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
Hi guys I'm looking for some advice. I have recently removed a wall socket that we no longer need, and have wrapped the individual Live, Earth and...
Good afternoon, I purchased a 25mtr coil of PRYSMIAN 6242Y 2022 GREY 2.5MM² TWIN & EARTH CABLE in Screwfix at the start of July and found while...
