A
Andy82
Hi everyone,
I need some advice about how to chase into engineering brick. Full story below.
I've mounted a TV onto the wall, not my preference but long-story-short it's happening. I'm running the cables (HDMI and aerial etc) behind the wall but it's a solid wall. So, I've bought some square trunking (30mm deep and 60mm wide) that gives me plenty of space for swapping wires etc and away we go to start chasing into the wall:
Old old plaster comes off nice and easy using a multi-tool with a masonry attachment, nice and neat. I then need to go a further 2.5 cm into the brick all the way down the channel so that the trunking is deep enough to plaster over. The first few bricks at the top of the channel aren't too much trouble, I'm using a combination of drilling holes to the correct depth with an SDS drill and then knocking out the brick with a hammer and scutch chisel, so far so good.
BUT, the bottom two bricks are like nothing else, I assume they are engineering bricks. The SDS drill with a masonry bit doesn't make a dent in it and I've actually managed to break one of the teeth of the scutch chisel when I was really going for it!
Can anyone help here? I only need to get about 2.5 cm into a 60mm wide section of the two remaining bricks. Any advice as to what tools will be my friend?
Thanks in advance!
Andy
angle grinder with a diamond blade, but caution there will be A LOT OF DUST.
Reactions: Baddegg
a lot of dust .LOL.
I had a job like that a while ago with a concrete wall. Customer wanted a massive TV on it with all the tec in a bespoke unit the other end of the room. Ended up studding off the wall enough for the cables to go behind then plaster board on the studs. Took a day to do apart from the plastering!
Reactions: Rpa07
Hi,give us a clue as to building construction,type,age,etc,and i'll tell you how to achieve success:)
What ever get up to in my spare time is of no concern to you, if i wear black latex or red is preferd.
LOL .:)
Try and avoid bashing the bricks into oblivion or you'll probably loosen them completely.
Bunch of faggots, club hammer and a bolster.
Remember my apprenticeship had to chop in twenty 45 mm double boxes in engineering bricks with a club hammer and bolster it was soul destroying, thank f*** for a kango
You where lucky, when I where a lad it was 40 doubles and all they gave me was a blunt rawl plug tool and a toffee hammer...........
No spoon
  • Funny
Nope, I had to use the rawl plug tool to spoon sugar and to stir the tea as well......
I once used my pad saw as a butter knife
like this?
images
  • Funny
Reactions: Tony Reidy
Glad the grinder did the trick..
Talking of engineering bricks...
I had a kitchen to do last year, with some of the hardest engineering bricks I'd ever seen.
4x 5.5mm SDS drill bits and 3 sets of Diamond blades on my chaser, you had to deburr the wall after running a cut up the wall.. There so much metal mixed in with some of the bricks you could literally stick a magnet to the wall.
I got there in the end, anyone else ever seen bricks like that ?
Reactions: Jim_e_Jib and DPG
They where thinking a few years back to turn steel mill waste/dust into bricks for construction, known as waelz slag, maybe it was something similar from years back.
Reactions: AJshep
Could well have been. It was an old house, probably 1940s hopefully I won't come across them again, as it cost me £100 on diamond blades.
you had a TOFFEE hammer..? Bloody Luxury! we had to cut out our shin bone and head butt it against the wall for 5 nights solid... but you tell youngsters today and they just don't believe you..
I have a wall in the house made of some sort of fibrous board that's been there years, took the death off my pad saw when trying to cut it.
There are many houses around where I live built from a light yellow brick known as a Marland brick, after the clay works where they were made.
These bricks are undoubtedly the world's hardest bricks, destroying SDS bits with ease, and causing diamond cutting discs to cook and warp.
There are black areas inside of them where a diamond disc makes next to no progress, with a black lava like substance oozing from the slot and solidifying on the surface.
...There are black areas inside of them where a diamond disc makes next to no progress, with a black lava like substance oozing from the slot and solidifying on the surface.
Could it be ectoplasm ?
Are the faggots for when you get hungry half way through the job?
What I'd like to know is where can you get a decent ------ these days?
Every butcher I try generally gives a response along the line of "there's no demand around here mate".
Every time I find myself passing through a new town I try to find the local independent butcher to check out there stock.
Does this make me a ------ tourist?
  • Funny
Chasing into engineering brick
Electrical Engineering Chat
Andy82,
Intoelectrics,
