L
liamj2003
Hi all,;)
I have included a photo of my fuse box, as Im unsure of the type (name), Question is:
Im aware there is no protection, with as it stands now, I understand I can just break away the front of the fuse casing to house larger fuses but with switches (if this right) and what are these switches called (micro RCDS or something)
Currently I run all my computer, TV etc from a surge protector, but I have recently installed additional sockets, including one that sits mid level directly behind my flatscreen tv on wall (power socket for TV) and obvoiusly this is no longer surge protected so I guess I need to update my fusebox so some sort of surge protection is in place. (is that right)
Any suggestions/help is greatly appreciated!
Many Thanks
Liam
It looks like an old Wylex rewireable fuse box. Wylex do a replacement fuse carrier that will take an MCB. That will not however provide any RCD protection, if that's the type of protection you want.
I'd strongly advise contacting a local qualified and registered electrician for this work.
I just dont want my TV to have a surge of power if a storm happens and blow it up, I just need to replace my external plug in surge protector for a built in one I imagine. is that right?
Liam.
Bythe sounds of your post i dont think that you are an electrician, and youshould arrange for a electrician to replace fuse box for you. when we replace fusboxeswe also test the cables and circuits to make sure they are safe and don’t presenta hazard.
Yes your right Im no electrician, but always cautious and wouldnt play about with anything more than adding an additional socket (and Im waiting for those to be signed off before the electrician connects them) Its sounds by your answers that Im maybe getting confused,
This is it in a nutshell - My TV used to be plugged into a surge protector extension lead, now it has its own dedicated single socket directly behind TV mid level up wall (as TV is on wall) Am I right in thinking that it is now no longer protected from an electrical surge, so How do I protect it again, do I need it protected?? Im worried my old fuse box will not serve any protection as it currently stands (see pic) so I guess thats what the MCB's are for. (yeah or not)
Many Thanks once again
Liam
Suggestion...!!
Get a local spark to price you up a New Consumer Unit with RCBO Protection
also get him to cost in a 230-250 surge protection module to fit on the unit also!!
i would suggest a price of around £500 (providing no electrical bonding is required to gas and water, if so budget a further £100-250 depending on cable run) will get you up to speed and fully protected from SURGE / Electric Shock and Overload...!!!
use this link to check for a local spark..!
Local Authority Building Control - SEARCH
as any work done at teh fuse box in terms of upgrades needs building control notification etc...!
Just to clarify
MCB / Fuse = overload protection for the circuit pulling to much power and melting the cables
RCD = Protection from electric shock
Surge Protection = Protection from electrical surges on the grid coming in to your home and blowing the tv etc up...
RCBO = MCB + RCD combined :)
if you changed the fuses to switches you will still not have surge protection to that socket!!
One thing for sure, your not going to get surge protection units, and the RCBOs in that sized recessed CU, Much better to use a surfaced mounted CU over the old CU back box of sufficient size to accommodate the P/Os needs.... Preferably of a make, that has all of it's RCBOs readily available!! lol!!!
if you post your location , ther might well be one on here can come and sort it for you.
i agree with what the guys say , upgrade you Fuse box (Consumer unit ,Sorry being a bit watsit today lol ) but doing this will not protect from lightning strikes as i have found out , melted my surge protector blew up my PC to opps , insurance paid up though , but agree with the guys get a surge protector socket and use this , most surge protectors come with a guarentee that if equipment is damaged you will be covered up to a set amount
Nick
Reactions: 2 people
Reactions: 3 people
lost me Engineer!!! who mentioned the CU was recessed??? look like a standard surface one to me! check the shadow on wall... :)
you been playing a a Nintento 3ds and screwing ya eyesight up lol..
Better to use a Furse surge protection unit fitted into the CU unit, this will protect the whole installation and far more robust than surge protected sockets and extension leads...
Just had another look at the photo, still looks recessed/flush to me!!! Quite common to find too from that era!!!
Best let the OP to confirm then ...surface or flush!!! lol!!!
look at the shadow cast top left. surface, surface, surface. sorry durham. got carried away remembering the film, above us the waves.
Reactions: 3 people
They do but most you won't get a 32a for love nor money Most wholesalers have had them on back order since June last year!!!!
That must be because I must have most of them in my shed :D
I didn't know they are scarce, I have loads of them
hang on to 'em till the price goes through the roof, like square D QOs
hahahahaha!!!
terminology is all wrong i them films!! dive dive dive!!! lol....
Diving Now Diving Now
Submarine Passing xxM all compartments check round for for leaks and report to control room report on extn ---
Submarine about to Return to Periscope Depth.....
Standby to surface
Surfacing Now!! Surfacing Now!!
or the most scary thing that can happen is
broadcast of SHUT BULKHEAD DOORS..... Claxon x 3 and then an aggressive but clear voice shouting EMERGENCY STATIONS x3 FLOOD FLOOD FLOOD
thats scary!!!!!!
hahahahaha!!!
thats scary!!!!!!
and captain larry grayson saying " i told you, SHUT THAT DOOR"
Sorry for delay yes it is surface mounted, not recessed,
So by the sounds of it my TV wont be protected to the same level as it was when it used to be plugged into the surge protector, Ill eventually update the unit to a modern regular one, but cant afford to be too picky about "over the top" electrical protection.
Many thanks for all your answers..
Liam
I
G
Australia
Deleted member 19807
S
4K
A
Updating my 1985 Fusebox
Australia
liamj2003,
liamj2003,
