J
jmilla
Just wondered what others thought of using through crimps or other means of connectors which aren't really easily accessible & tester friendly. The Ashley j 501 loop connections boxes are great but quite expensive and take a while to connect. Any ideas of what could be used other than con. Blocks?
Thanks.
Depends on the situation they are in. Are you refering to connections for down lights?
Yes downlights & switches in dry line boxes but yes mainly downlights. Quick replies. Unexpected. Cheers guys
no not yet but can you get the feeds into the the click flow connectors as well as the loop in loop out ?
Will try the click connectors. Thanks. Also I've seen the eureka box. Doesn't look too great, but could replace the choc box
hey guys. I'm new to this site as well as forums go too.
jmilla,
jmilla,
