Discuss ISE 10 W256W (ASKO WM70.1) washing machine won't turn on in the Electrical Appliances Forum area at ElectriciansForums.net
flannel
Can anybody please offer any guidance with the following problem.
The power button doesn't work but when turned off at the socket, left a few seconds and turned back on, the lights briefly come on.
The history so far is here.
has that machine got a brushless motor if it hasnt check the state of the motor brushes also check the condition of the mains filter as they are notoriously un reliable on that model
Thanks James,
The problem is fixed - I attached my multimeter to measure the voltage across the on switch and as I turned the power on at the wall, the machine came on and stayed on and now seems to be fully functional again!
I can't be sure if it was connecting the multimeter that fixed it or one of the following:
  • Measuring the voltage across all diodes (using the multimeter diode setting).
  • Measuring the voltage from base-to-source and base-to-collector on all transistors (using the diode setting).
  • Measuring the source-to-collector resistance on all transistors.
  • Allowing enough time to pass for something to dry out (although there was no evidence of water).
  • General movement of cables if there is a broken one (including taking out the motor control board to check the fuse).
Now when I turn it on at the wall, it doesn't light up until the on button is used.
Thanks James,
edge connectors are a major problem on washing machine pcbs a lot of faults can be cured by just cleaning the contacts on the board a use a commutator cleaning stick for this or a fibreglass pencil
Reply to ISE 10 W256W (ASKO WM70.1) washing machine won't turn on in the Electrical Appliances Forum area at ElectriciansForums.net
My 9 year old ISE 10 W256W (ASKO WM70.1) stops at 4 minutes from the end on the Everday-wash cycle. I've drained it with the tube (not much came...
hi, I qualified as a sparks in 2008 and after doing many maintenance contracts mainly with the NHS, I only have time to do private jobs and my...
8K
Looking for some advice on what I've discovered is the electrics situation in my rental property. I'll note that before I moved in here I made...
11K
M
Peugeot 206 cc 2003 - The story so far...... whilst driving in the rain my wipers stopped working resulting in recovery back to my house with the...
8K
mrpinky
M
Hello, Went out to visit a house last night and the owner admitted that the best description for her electrics was "Interesting" Anyways a local...
