W
wstevew
If you have 2 SMA inverters on netID 2 and they show as Master and Slave and you wanted them set up as Independent Inverters on their own net ID how would you go about doing this.
Looking through SMA documents they suggest that if you power up 2 inverters on the same netid they automatically setup in network mode as Master and Slave based on signal strength.
Apparently Isolating them and setting them to different netID numbers and then booting up again, Sunny Explorer connects but just says "reading daily data" but never does.
Put them back on the same netID and it works again.
Is there something else that needs to be done?
