Search the forum,
Discuss Supply Protective Device in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You come to fill in the section of a PIR entitled "Supply Protective Device" but the supply protective device is sealed. Do you:
a) Break the seal to examin the device? (you are not allowed to break the seal!)
b) Take a guess, but in that case do you enter 60, 80 or 100 for the rated current?
c) Declare a limitation and just leave the section blank.
d) Waste time phoning the distributor (who probably doesn't know the answer anyway)
I have to agree with the first two replies re LIM, as a retired EEB inspector I can confirm that the carrier markings are not indicative of the fuse ratings, there are two size carriers smal and large, the small is normally 60A but could be 80A but no more, the larger carrier is normally 100A but we had fuses affectionally known as fat 60A and 80A which would be fitted at the inspectors discretion eg for 16.00 tails.
NB it is not illegal to break seals for safety or emergency reasons, only abstraction of electricity is illegal
Thanks, that's what I thought. Its just that my NICEIC inspector gave me the impression, without actually saying anything, that I should have done better than to declare a limitation.
Reply to Supply Protective Device in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
