- Jun 4, 2017
- 3,806
- 5,856
- 12,688
- United Kingdom
- Business Name
- Sulis Electrical Services Ltd
Called to a small job this morning, woman in her mid 40's says her doorbell is not working properly...
says it keeps going off but nobody is at the door as she can see the front door from her kitchen window.
So I arrive and check it over. The switch is in good order and the wires go all way back to the consumer unit, however it then gets a bit weird the wires are not even connected into the consumer unit anymore and are tied up next to it. the transformer is sat on top the shelf next to Cu covered in dust and grime and has been for some considerable time looking at it.
No voltage at all on the bell wires.
She is adamant she can hear the doorbell going but how do you tell her its all in her head! there is no doorbell and the old one is not connected!
Not one to make light of peoples mental health issues but she is clearly not the full ticket. Charged £20 for my time rather than usual call out fee as I didnt do much apart from put a blank plate and membrane grommet in the CU to fill a gap, dont want her poking inside.
For some reason i keep getting calls that in all honesty should be going to social services.
