Discuss Extending Bluetooth over Mains Power in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
B
besafe
I have installed a SB 4000TL (with its built-in Bluetooth) in a workshop about 100 yards from the main farmhouse.
The Bluetooth works fine with my laptop, but won't extend to the house ... which also has walls 2-3 feet thick.
The domestic incoming supply and isolator is in the workshop.
Is it possible to use a Homeplug (or similar) to extend the Bluetooth into the house?
Or is there another solution.
Any advice will be appreciated, thanks
Reply to Extending Bluetooth over Mains Power in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
I want to use a manual change over switch to safely connect a 21kVA single phase tractor PTO powered generator to my mains supply in case of...
Currently quoting for a job that needs to be done next week and working out how best to proceed, so thoughts welcome. Current situation: -->PME...
4K
Hello, So I am having my newly built workshop wired up soon. I had the electrician around yesterday to talk through the job. I will be running a...
5K
Looking for some advice on what I've discovered is the electrics situation in my rental property. I'll note that before I moved in here I made...
11K
