In response to SparkyChick’s post:
Not sure about fixing accessories to the inside of cupboards.
Don’t like the two lengths of trunking feeding the accessories under the cupboards.
Don’t like cables fixed in place under floor boards.
Do like the metal plates protecting cables through joists.
@Deuce , @gazdkw82 and @Pete999 ...
Based on the fact you're all saying short coursers lacking sufficient practical experience and knowledge, is it entirely inconceivable for you that some may have sufficient practical experience and knowledge before they go that route?
This is often something that's stated... insufficient practical skills and experience... so what practical skills and experience do you believe are required?
I was saying you won't get those skills from a 4 week course. Of course, some people just have a strong practical ability and enough common sense to get things mostly right without specific training.
Likewise, other people can work on site an entire career and still be fairly useless!
Reactions: DPG and JAWS
Thanks @spinlondon
Just some questions if I may :)
The accessories in cupboards... what do you see as the issue with that?
Two lengths of trunking... I agree, not ashamed to say I made a mistake, should have used bigger trunking to begin with. Just couldn't get all the cables in one length. Genuine mistake.
Cable fixed in place under the floor boards... I'm guessing is the cabling around the Surewire lighting junction box? Generally agree, the only cables that were fixed were those going to the boxes themselves. They have cable clamps anyway and movement was limited. The rest were just pulled in.
Reactions: DPG and Fitzy
And I absolutely would not argue with any that holds that view, because it's fundamentally correct. There is not enough practical time on the short courses.
There's enough to get the basics of wiring down, but once you start to throw into the equation construction methods etc., forget it.
Thanks @spinlondon
Back in the days before MF JBs, JBs were fixed to platforms constructed under the floor with all cables clipped prior to making any connections, not only was this good practice, it made connecting a lot easier, and with large lighting JBs a work of professionalism, not like they teach today make the connections and chuck it (the JB ) under the floor. I some times wonder as long as the JB position is noted on the EIC why we can't still use them, I suppose it is the lack of training given out in these "be a Spark in 5 weeks courses" no skills taught just how to get the exam passed.
  • Disagree
Reactions: 123
That's a good point. In this instance as long as the individual has at least a few years in the trade then I'd consider that acceptable experience.
The overall problem for me is the people who run these courses generaly help you through. Some of the ones in my class we're clueless without being promoted in the right direction (even at the simplest task) not all are like this but some are and that's the danger.
I think after you pass you should still need 2 years experience before you are classed as competent. that doesn't apply if you have prior experience.
Electrical work is very diverse. Personally I only believe you can be classed competent once you have had exposure to numerous situations that you can only get working out within the trade.
I don't see why the round 30A JB exists any more. Old practice had often seen the cpc twisted together and left outside the JB, this practice has carried on and those that use them still do this today.
With Wago's and MF products so readily available that do a better job, and a quicker install, why would anyone think installing a round 30A JB is a good idea?
You could use this analogy for most things in life, like driving lessons, they only teach you how to pass the driving test, not to drive in general, that’s learnt after you pass. So should we all have been put on a special licence for the first few years?
Take Firefighters for instance. Now a days most counties Fire Brigades only put new recruits through a 6-8 week basic training course, then the rest of the training is done ‘on the job’, yet when I joined in 1989, I had to complete 26 weeks basic training which was much more intense and activity based and was a minimum of 3-4 weeks per module of the job involved. Now, that has to be crammed on to 6-8 weeks which is roughly 5-10 days per module, BUT, they’re still competent firefighters who when push comes to shove can tackle an incident singled handly.
Yes, however a firefighter works within a team. I bet the recently passed firefighter will still be monitored as if he/she was a junior.
Some electricians coming out of a 5 week course and no really experience are going it alone and taking on all sorts of jobs
We did.---Classroom we had already run the 2.5/1.5 PVC/LSF around the perimeter of the room asked to add two extra sockets cut 2.5 near where one socket would be put the other leg to first socket new cable between that and another new socket then back to 30A JB above-suspended ceiling screwed to a wooden panel. We were unable to pull the new cable back to the previous socket in the room so JB that we had in the van helped us out.
This is a key point I think. Many dodgy shortcuts are taken by tradespeople because they want to make the physical installation easier. They may well know it's wrong to run cable the way they do, but they do it anyway as they don't have the practical ability to adapt the property to run it the correct way.
This is compounded when a customer doesn't want to have to much messy work done, and gives off the impression they want it done easily/cheaply. I'm sure often the customer is as much an instigator of these shortcuts as the spark that nods along and does the work. It's on the sparks shoulders in the end though, they are the professional.
  • Agree
Reactions: Fitzy
I thought you guys may be interested in these pics from a "spark" who did one of these 4 week courses and went straight to self employed!
This was for a house Re-wire, I actually quoted for this job originally but the house owner chose this contractor instead, but then contacted me afterwards to take a look as they were concerned by the work completed. :rolleyes:
When I walked in and saw the work, I was truly shocked, it was truly dangerous!
I contacted the Niceic for the homeowner who have now completely Re-wired the house with another contractor under the platinum guarantee.
Original "Spark" is no longer registered, so its good to see the Niceic do take action!
This was apparently a finished job which she has been paid in full for :eek:
Anyway have fun with these :D:
C/U was moved, so quite rightly a switch fuse was installed, not so sure on the insulation methods mind:
Urm...., oh and thats data going behind the C/U there...
Wet pants is always wrapping his pipes around my cables, I know I will wrap my spaghetti around his pipes..
Meter tails and more chased horizontally through wall, not in a safe zone..
Now what is that bare wire for, lets poke it back out of the box...
Expanding foam doesn't seem to be working at fixing the boxes..., oh and that damn bare wire again! and no grommet! o_O
Well the expanding foam wasn't working, lets just leave them hanging...
Its all too much work chopping the boxes into the wall..
Wago boxes are over-rated...
This surely has to be up there with the worst?
Sorry chap, but you've started a controversial thread which is fair enough but then given no further input. The above accusation about the Domestic installer courses are worthless without backup facts which you have failed to give.
The above work is not the fault of a short course in the slightest, nor is it the fault of any course or apprenticeship. It is just some person who doesn't give a xxxx about themselves or the safety of others.
Response to @SparkyChick:
Some would say that accessories should be fixed only to the fabric of the building.
From your picture, it looks like the accessories are attached to the more solid side of the cupboard, not the flimsy back panel.
As such and taking into consideration that it’s a fitted kitchen (which makes the cupboards virtually part of the fabric of the building), I don’t have a problem with them.
However, others (including assessors) may have.
Surprised you couldn’t fit all the conductors in just one length of trunking?
Don’t like cables fixed under floorboards and above ceilings, as it’s a pain when it comes round to rewiring them.
Thanks hon :)
I know what you mean about fixing stuff to flimsy panels and I agree. That unit was pretty sturdy and was well fixed, but I understand what you're saying.
In the trunking, 2 x 10mm to/from the CCU (requested for future proofing), 2x2.5mm for the ring and then 2x2.5mm 1 each out of the FCU. It was tight in the straight bits but handling the bends at the T, was almost impossible.
I agree on the cables fixed under boards, that's the only place they were fixed, by virtue of the fact the box requires it.
Thanks for taking the time, it's much appreciated.
Reactions: DPG and Dave OCD
SparkyChick, that is really nice quality work. You are also clearly very knowledgeable, much more than many graded sparks IMO, and it seems mad that you won't get a JIB grade with the quals you hold. It's a shame they don't still do the NVQ3 with the knowledge assessment, you would walk it.
I find the constant belittling of short course people rather tiring too as it puts a divide in the forum. I'm a fully qualified sparks and I work in a large firm so there are also many fully qualified idiots lol.
The crux of it is, you never stop learning, so whatever someone's start in the industry is, push to be the very best you can......and in all cases....... better than your colleagues.....which is not hard where I work haha.
SparkyChick, that is really nice quality work. You are also clearly very knowledgeable, much more than many graded sparks IMO, and it seems mad that you won't get a JIB grade with the quals you hold. It's a shame they don't still do the NVQ3 with the knowledge assesment, you would walk it.
Thanks TJ :)
I'm actually on the road to a JIB grade :)
I've taken the level 3 tech cert exams and passed them all (my motor control knowledge let me down somewhat on the science exam because I've just not done much of it), got one written project to do which contains quite a bit about motor control so I'm learning quite a bit for that.
Working on my NVQ3 portfolio and have my AM2 booked for December :)
All courtesy of funding by the Welsh Government.
Top Stuff SparkyChick, you'll be Technician Grade in no time! :)
It's totally about the person, not the course. The only problem with the courses is that they're sold as an instant entry into a well paid job. However disastrous that might turn out to be.
I am completely unqualified. Not just electrically, but in general - I left school at 14. I've never felt limited in what I can do by anything other than a safe knowledge of my own limitations. For example, I have a thread on the go on here right now about whether to isolate or earth a rather unusual piece of kit... There are sparks on here that I know enjoy to mull over such problems in far more depth than I have knowledge to match.
In other areas I sometimes ask for help out of simple recognition that I'm not a spark! Today on site, I bought in a couple of 12hp pumps, motors wired in star. They spun in reverse when I hooked them up to the generator fed supply, despite my knowing the configuration was correct and already tested in my workshop. Somewhere in the miles of cable and/or portable distribution box there were phases wired incorrectly. I asked one of the site sparks if they could check the back through with a phase sequence indicator, or at least check the generator to rule that out. He shrugged and said just swap the phases on the motor... Of course I know that I can do that!!! But as a fairly mature spark he should have known it's correct to maintain correct phase to (in theory) make balancing calculable. He also shouldn't invite me to rewire a 3ph motor and put it back into use! To be fair we both work in an industry where in reality solutions matter more than method. And he probably guessed I could sort it in minutes. I sometimes wonder if my knowledge would be as good if I were trained... Having to work it out alone has made knowledge feel very valuable indeed. And my discipline largely comes from knowing I have to be pretty perfect as I'm so easily criticised if I make a mistake, or even a silly comment, when I can't claim to have even part p to my name.
I'm not good at my job because I've done it for many years. I'm good at my job because I choose to do things that I'm good at naturally. So I conclude that the real problem is the selling of the courses, making it seem as if anyone that fancies a pay rise can have one in just a few weeks. In reality you either are right for a line of work or you are not.
Email
Time zone
Last seen
Quality work by a electrical trainee.....
-Matt,
Deuce,
