A
andysparkfree
Hi all, just thought i'dd share the picture of the live distribution board we came across this afternoon following a callout
not only was this live when we got there (seems that the fire brigade removed the wrong fuse from the ryefield board) but is a shocking example why every old distribution board should be changed to metal asap
TBH, I would be saying that the manufacturers of these boards have a LOT to answer for, but, money talks, and they have bought their way out of trouble.
Reactions: Risteard
A bit of a clean and perhaps a new front cover and it'll be fine. Bloomin Drama Queens. :D
If it was nothing to do with the fuseboard, you’d probably have to put a temporary supply in for the clean up anyway, wouldn’t trust a metal board after the fire service spraying their hoses all over the shot!
Quick jet wash to clean it all off and a hair dryer then pop down the supplier tomorrow for a new empty cu and it will be good to go.
  • Funny
Reactions: static zap
What a strange thread, this is a shocking example why every old distribution board should be changed to metal asap backed up by the distribution board was not even the cause of the fire!
I should hope you are not preaching this to your customers.
no not really in to job creation, was more thinking of it db was metal, it could of been isolated easier ! Safety!
Reactions: PhilGas and DPG
As i would hope that you could lift the flap and turn off the main switch a lot easier
as you can see in the picture, nobody would really want to stick fingers or anything else close
If all terminations within a DB are made correctly and tightened properly, then there is no reason why there should be overheating to cause a fire. The majority of burnt cables I’ve encountered are purely down to the fact they haven been tightened sufficiently. The change to metal DBs (in domestic) to contain fire is akin to putting a bucket under a leaking roof..........fix the roof!
If installed correctly there is nothing wrong with existing plastic DBs.
It's interesting to see that whilst the case and front cover has mostly melted away the important bits (breakers, main switch, cable insulation and even the structure around the busbars) has remained largely intact.
Email
Time zone
Last seen
Metal all the way, no brainer
andysparkfree,
Midwest,
