B
bikeman
This is my first post so Hi to all
I have to wire in a couple of 16 amp 3 phase wall sockets in a work shop.
The ones I have been given are 4 pin.
If I run Line 1, Line 2, and Line 3 standard brown Black Grey I am guessing the 4th pin is for earth and power is between each phase?
Just checking as I have this naggin doubt that the 4th pin would be for neutral.
I have to install 2 in the work shop and there is a spare 20A 3Phase CB on the board I am guessing I can ring each line back to the board?
Thanks for any responce
Sounds like a 3 phase supply for a motor no neutral needed. So yes L1 L2 L3 & cpc.
I personally would not wire these on a ring. I would run in a seperate radial for each 4 pin back to seperate MCB's.
4 pin = 3phase + earth.
5 pin = 3phase + neutral + earth.
As the guys said, one circuit for each, happy days.:)
as above and you also need to think of motor protection methods, you dont want somebody to test a 1kw motor using a socket on a 20amp beaker
16A 4 pin wall socket
Electrician Talk | All Countries
bikeman,
pmac10,
