Discuss Green Deal & Eco Funds in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Thanks Fellas.
If anyone covers the North West of England and fits boilers etc could you send me a message and I'll pass on the details.
Not having a lot of luck trying to get a decent rate from providers that are accepting new installers. Off for a meeting with Green Deal Central tomorrow so I hope a good deal can be made.
If not then I don't know what to do, we currently have 5 jobs ready to roll and around 30+ jobs pre qualified ready to survey and EPC.
Pm me matey
Just as an update - we are now getting funding through Green Deal Central fitting 2-5 boilers per week. Were having to turn some jobs down due to low funding though.
Thanks Eco Deal, Just HHCRO - boilers I'm dealing with at present. Off out on a solar pv install today, pm me your number and I'll try and remember to give you a ring tomorrow.
DECC consultation on changes to ECO closes 16 April - https://www.gov.uk/government/consultations/the-future-of-the-energy-company-obligation
One of the main changes that could help homeowners will be the inclusion of loft and cavity wall insulation under CERO.
Crucially it is clear that standard insulation opportunities can, at the moment, deliver carbon
savings at lower cost per tonne in ECO subsidy than harder to treat measures. In the context of
immediate concerns about the overall costs of ECO and its impact upon consumer bills, it is
more difficult to justify a policy which excludes these measures. The Government therefore
proposes that loft insulation (including both virgin and top-up loft insulation) and standard cavity
wall insulation measures installed from April 2014 should be eligible as primary measures under
CERO. Therefore, the current differentiation between hard-to-treat and standard cavities would
be removed, with all forms of cavity wall potentially eligible for treatment under CERO
We would propose that the eligibility rules, as set out under the current legislation, on measures
under CERO would continue to apply to the new primary measures. So to qualify under CERO
loft and cavity wall insulation will have to:
a. be a recommended measure;
b. improve the insulation properties of the premises; and
c. comply with PAS 2030.
For loft insulation as a new primary measure Government recognise that a de-minimis level for
the depth and area of the insulation is appropriate to ensure optimal treatment prior to triggering
secondary measures. We therefore propose that to support the ‘secondary measure’ status of
another measure loft insulation must be:
a. installed in lofts which currently have less than or equal to 150mm of insulation (to a
level of at least 250mm of insulation); and
b. installed to at least 50 per cent of the total area of the loft.
For cavity wall insulation as a new primary measure we propose that a de-minimis level for the
area of the insulation is appropriate prior to triggering secondary measures. We therefore
propose that to support the ‘secondary measure’ status of another measure cavity wall
insulation must be installed to at least 50 per cent of the total exterior-facing walls of the
premises.
Reply to Green Deal & Eco Funds in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
At Electrical2Go, we have recently broadened our product range to include water heaters. Our goal is to offer comprehensive solutions for both...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
At our church, one of the things I've done is sort out the heating wiring (as best I can for now). The schematic is as shown below. The theory...
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
