Discuss Continuity on lighting circuit - weird results? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi
Running a quick test on a lighting circuit today, was doing R1 + R2 on downstair lights. Everything seemed OK, but upon trying to prove polarity by using switches obviously upon switching off the circuit goes open but when tried switching on again and testing again I got a wildly different figure. I initially thought I had a bad contact as figure was jumping about a bit but did after some messing get it to settle at a reasonable figure but upon trying the switch (off test O/C, switch on and test again) got another miles out figure. Tried this a few times and the readings went between approx 0.5 ohms and about 3.5ohms and everything inbetween.
Each time once I had a reading I disconnected probes then reconnected them and tested again to prove it wasn't a bad contact that was causing the problem but this gave results within 0.05ohm of each other. It was just upon using the switch it seemed to badly throw the result.
This was in fact present on 2 switches on the whole downstairs lighting circuit (the second case not as bad but still giving results different enough for concern).
My hunch is the switch is buggered? Is this a view others share? The light fitting was really awkward so had to test a number of times to confirm that it wasnt just a case of my probes not having good contact but it did seem to just be the switch causing this issue?
Anyone else experienced this?
switches can be a pain,they're prone to dust ingress and all kinds,since they are only cheap the best thing is just swap them then you can rule them out for sure,but that's almost certainly the problem.
Reply to Continuity on lighting circuit - weird results? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
