Discuss Flat roof job in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
S
solgen
Nothing for months then this... any ideas welcome
Client has a large flat roof up about 10M it's got loads roof lights and a lift overrun area. If the panels are laid flat (not tilted) they can be laid next to each other and I can get the required number of panels installed.
What sort of mounting system allows this? Is there a ballast system?
look foward to suggestions
Panels are often not warranted if they are laid flat, they are not efficient other than during the day in the summer, and they will not self clean when it rains, so we would not recommend it. However, if your customer does want to go ahead, you could make a aluminium frame and ballast this with the correct amount of weight after a structural calculation of weight requiements. We could help with this set up if required.
Alternatively you could use the Sunmount system from Solion, this has a 10 degree pitch I believe, and requires no ballast, or you could use Console from Renusol which needs ballast and has a 25 degree pitch.
Schletter have systems too, even increase the top rail height greater than the bottom rail creating a slight angle. I believe Jetion do not have a minimum angle for warranty...
No SolarCity we don't unfortunately, we do stock all of the Renusol systems though including Console. We have been in discussions with Solion and it is a good product to be fair, but not placed any orders to date. It is expensive when compared to Renusol and we are not sure how much demand we will have with the market as price sensitive as it is.
poheZ, only just seen your reply, but if you want to PM me your email address I will send you the relevant info and some prices.
They are versatile and could not be easier to install. Only downside is you need a roof that is structurally capable of taking extra ballast weight. How much weight depends on wind load which is affected by factors such as the height and location of the roof and position of the panel on the roof relative to other panels in the array.
In most flat roof installations its the only option as you cannot go drilling through the roof's. I think its around 14KG per tray though so the weight soon builds up!
Reply to Flat roof job in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Does anyone know of any procedures and/or devices made specifically for temporarily raising solar panels and their associated ballasted racking...
Hi! I’d like to install a pedestal-mounted (230 V, 30 A max - programmable) EV charger close to my driveway, which ends about 12 feet away from...
4K
Hello, I’m not an electrician and I have a question in relation to Dimplex Duo300n. Some background information: a couple of months ago I have...
7K
Hi Guys, First time posting but I've been commissioned with essentially running new cables from the head to 5 flats, due to the ground floor...
Good morning, I'm hoping that a crusty retired construction super is welcome here. I'm remodeling a cabin that has the old 2-wire electrical...
