- Sep 4, 2025
- 2
- 0
- 50,001
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United States of America
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hi I have an interesting situation... I live in a condo and unfortunately for me the two HVAC systems/fans are on the same circuit as my main desktop computer system. Recently every time either of the HVAC systems turn off I get a little audio blip out of my speakers and sometimes my monitor will flash on and off. My desktop computer system is hooked up to an APC BE850G2 battery backup. For some reason those spikes are getting through to my components. IIRC also sometimes when the HVAC systems turn on I get sags that have a similar effect although this hasn't happened super recently.
Is this something to worry about? Can it cause damage / wear and tear to my components? If so how can I protect my components from said spikes? I called APC and they said I would need to get a $1300 enterprise battery backup which is a fair amount of money to invest.
Thanks!
Thanks!
