- Jun 30, 2010
- 9,196
- 8,031
- 10,256,798
- United Kingdom
- Electrical Engineer (Qualified)
No, it's a metal MK Sentry Consumer unit of current design. I've fitted a few.
In England and Wales (Part P 2013 and 2010 editions respectively) there should have been a notification submitted to the local authority building control that the consumer unit has been replaced. There should also be an Electrical Installation Certificate for the work (a consumer unit change requires this).
Hi @Benuk. Personally I wouldn't sign anything until you have seen the above or after one is done. You do not know the condition of the electrics and as you say, if they have lied about this then you never know what else they have done.
