Mar 29, 2022
36
Newcastle-under-Lyme
Other
If other, please explain
Possible trainee
Quoting for a CU upgrade soon and it's the first time I've actually quoted one myself.
Any tips on how best to approach it? I get the principle of materials + time, but is there another stuff to watch out for that might not be obvious. Things that may have tripped (no pun intended) people up in the past that I might also miss.
Also I'll be testing before doing the upgrade so global IR L+N to E, Ze & Zs, confirming end to ends & R2 tests, borrowed neutral etc. Clearly can't realistically doing this on first visit for quote. I appreciate all jobs are different but do you do any bacic Zs etc. at the quoting stage? Or pre-empt the customer that the first part of the job is testing the installation's suitability for a new RCBO/SPD board, and that might affect the end price.
All help appreciated - thanks!
Yes fused neutral. Good spot.
Reactions: Hakuhou
Also leave a note or get the customer to request the metre guy to actually fit an isolator ,most of the time there flying thru there day and moan cos it holds them up for 10 mins..last guy I asked moaned like hell saying there not obliged to fit one .don't know if customer got charged or not
Last DNO interaction I had was a relocation. They just banged in a new 80A 1361 head in and said the rest was up to me or the energy supplier, no obligation to fit an iso. The work was subbed though rather than being the DNO themselves, client said when they previously spoke with the DNO directly they said they would fit an iso.
The subbies did accidentally leave some nice DNO meter seals though, which was awfully careless of them.
Personally I have a tiered fixed price for a CU swap based on # of ways. This typically works for me, if I am fitting an iso the cost of that goes on top. I will always talk it all through with the customer first, and definitely visit the property rather than going off photos alone. I also explain my price includes some pre-lim testing, the results of which may impact the job, and result in additional works to actually facilitate the CU change, typically I try and lay this out for them using a borrowed neutral as an example. I include this in the terms at the bottom of my quote too.
Reactions: aliensbrains
I think that may have been established earlier in post .
Well if you are going to be pedantic about it, I think you mean "earlier in this thread" even if you did mean thread and referenced post, you forgot the preposition. 🤣
Yes I did mean that and was being pedantic.i once dared to tell my journeyman he was being pedantic because I threw away the cardboard lid from a box of screws .didn't go down well ,he made me look for it the rest of the afternoon even though I new it was crumbled up in the bin .😭
Other
Possible trainee
Any tips when quoting for CU upgrades
Domestic Electrician Forum
aliensbrains,
Jock from the north,
