Discuss Metal all the way, no brainer in the UK Electrical Forum area at ElectriciansForums.net
That’ll be the factory fitting that the sticker tells us to tighten before commissioning! Obviously the installer didn’t!
I have litrelly just opened up this lid. The cover is all sorts of melted but had just been put back on amd the N moved terminals. View attachment 47937
Im changing a shaver light, just opened it to test.
When will people stop saying these boards are unsafe fires are caused by poor workmanship not making sure connections are properly tightened there are thousands of these boards fitted perfectly safe installations done by proper sparks. The London fire service were the main complainants of pvc boards but agreed that bad workmanship was the reasons for the fires. I was called to a house of a friend who had no power and when I investigated I found her 80 year old father had decided to change consumer unit himself this is what sparks are up against.
Did he use 2mm earth sleeving for the CPCs I do wonder!
80 year old - nothing wrong with that . was he a sparks ?was his regs current? did he hold testing and inspection cert's ?
was he a member of a scam ? - just saying cause not good to be - ageist . I'm a 103 year old 'battery electrician'b.t.w - U'2s - PP'3s I can change any of them - The worlds my lobster
Anyone watching Counterpart? This looks just like the meltdown that caused a rift in the space-time continuum! I am in the process of replacing a metal CU that is a shining example of why plastic boxes were introduced, I'll post a picture as soon as I can.
speaking as a Kiwi, it beat me why you Brits insist on metal domestic boards. We've been using plastic boards for over 30 years without any significant issues. When I started working in the UK 2008 it felt as though I had dropped back into the dark ages. I reckon plastic is superior and much much easier to use. Metal boards are a pain in the a**e down by the sea
Reply to Metal all the way, no brainer in the UK Electrical Forum area at ElectriciansForums.net
Just interested in peoples thinking on using the neutral through the earthing system like I came across today. I've come across many wrong...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
  • Locked
5K
