Never seen anything like that, no damage to cable or in area of breaker I'd be expecting to see marks and no pattern to them. Never thought I'd say this but it does indeed look like someone has held a lighter to them.
That is an very low tariff, I would be surprised if it does not go off at regular intervals, I assume no electric cooking or tumble dryer as these seem to be the main culprits in these EDF switch off incoming RCD.Thanks Mike. Yes I believe you are correct, and second electrician has noted that it is on a 6kvh plan which he was surprised about and thought was low.
Could it be the case then that the smart meter RCD tripped and simply needed resetting and that was that. Perhaps the EDF person didn’t even need to change the main fuse (however that definitely occurred as my partner let the person in and they swapped out the fuse). She said they were there for 1-2 minutes tops and just switched it out.
It's unusual for the main fuse to go, perhaps it was changed because it was faulty and the incoming RCD did it's job and just needed re-setting. Is it possible to see a picture of the main supply/meter and associated works?
Oh yes it's covered now, although I don't want to post the first electricians work and have the forum rip it even further to shreds. Mr second electrician's work I will post once he's done.Couple of other points, is there a cover for that consumer unit? if so put it back on, but at the least take the metal handle (broom) out of area.
And I agree with everyone else that has commented, that the first electrician was on a job creation scheme, never seen burning like that in a consumer unit.
