J
Jackson Greaves
Hi!
I m doing my first build of an arcade machine. At the back of the arcade cabinet will be an IEC socket for mains power. Inside the machine I then need to split the electrical wires so that the one socket can power both the power supply for the console board (standard jamma power supply) and the LCD monitor. The monitor and power supply both take 240v AC mains power. I was told I could just strip back the kettle lead for the monitor and crimp connect the wires to the power cable for the power supply and wire them both into the back of the IEC socket together. Is this safe if both appliances are rated for the same voltage? To be honest I d rather use a junction box or something but not really sure what type of need or how to wire it exactly. I have slight electrical experience but still basically a noob.
Any help would be greatly appreciated
Cheers!
Cheers!
