Discuss Help needed re Megger 1553 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
JamesBrownLive
I have recently purchased a Megger 1553, but am struggling with the user manual....
The section of the meter that has two settings and is coloured orange is used to test continuity, that much I understand. What I am having difficulty with is the fact it has two settings.... I'm not sure which one should be selected for what??
The video demonstration shows a continuity test being done whilst the dial is set to the 1st of the 2 settings, the Ohm symbol. BUT, in the manual the section about continuity testing, has the second symbol next to it??
My gut feeling, from what I have read, is that this second setting is just to control the level of the continuity buzzer. Is this correct, or does it have some other function that I have completely mis-understood/overlooked?
I must admit, considering the unit's price, I was expecting some better documentation.
Thanks in advance
I believe one setting is for a low ohms continuity reading while the other is a continuity 'buzzer' the threshhold of which is user definable.
Thanks in advance
Hi JamesBrownLive
The first orange section on the MFT1500 Series is for continuity readings (R1+R2) whereas the second section is ideal for proving continuity, i.e. ringing through multicore cables or phone lines. The threshold can be ranged from 2 ohms to 100 ohms in 6 increments to allow for cable resistance.
Kind Regards
Megger Technical Support
Hi JamesBrownLive
Kind Regards
Is it true that you guys at Megger have a rechargable battery pack now for the 1500 series of MFTs?
Hi Amp David
Unfortunately it is not true that Megger have a rechargable battery for the MFT1500 Series.
It is quite possible that future Megger products may be designed to run with rechargable battery packs as this is has found to be a popular request by customers.
Kind Regards
Thanks in advance
use the first setting dont forget to null the leads
There should be a summary card "manual" also supplied in the kit - look through that as it goes through all the key uses/settings.
I had looked at the summary card before I had printed out the main manual, but since then, I must admit, it has just been placed back in the case.
Having just looked at it again, it would seem that the 'Summary' is much better.
For example, this whole thread was started because I was confused that in the main manual the setting symbol used next to the section on continuity testing was the 'buzzer' symbol, but on the summary card it is the 'ohm' symbol. So in this case the summary card gives out the correct setting, but the manual doesn't.
However, in my defence, I cannot be alone in thinking that the full manual should not be playing second fiddle to a summary card.
Anyway, thanks for the pointer. The summary card is now my first point of call.
Cheers
Reply to Help needed re Megger 1553 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I've recently bought a megger mft1720 second hand but when I have it to the ohms setting the reading continuously bounces up and down even with...
I am wiring up a new kitchen and conservatory. I'm not sure why I checked continuity between line and the metal back box of the light switch, but...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
I am installing a Victron Quattro in an island mode configuration (in the UK, the DNO is the NG). I will be adding a stand-by generator. My...
