Hello readers! 👋🏻 welcome to another highlight from us here at E2GO. In this article, we will drive you through some of our best EV chargers in our product range, and compare their features to help you decide which charger is best for you.
Picture this: you’ve just specified your brand new electric car in your favourite colour, with all the added extras like heated seats and the media pack...now you’ve just got to sort out the most important thing; the charging! The questions about charging loom over you like a cloud - what type of charger do I need? What brand is best for my car? Which will be the cheapest to run?
You need not worry, for we’ve pulled together a straightforward selection for you to consider.
Ohme 🔌
One of the most-renowned brands, Ohme is an award-winning manufacturer specialising in smart domestic EV charging. Founded in 2017, they offer a range of affordable, intelligent, and highly cost-effective charging solutions - all chargers sync seamlessly with all major electricity tariffs and will schedule charging during the cheapest off-peak windows!
For a tethered solution, Ohme offers the Home Pro (OHME0002GB002), a Type 2 7KW charger which is not only IP55 rated, but also IK08 rated for durability. This charger has an interactive LCD screen and is compatible with the Ohme mobile app, allowing you to be in full control - you can schedule charging, set battery percentage targets, and even add cost caps. The compact design - no bigger than 20cm wide - paired with a 5m tethered cable makes it the perfect charger for smaller spaces 🏠
If you’re after an untethered option, you can select the ePod charger (OHMEX1GB003-BL), a 7KW charger with a Type 2 socket. Designed with dynamic load balancing and over-the-air firmware updates, this charger will ensure the most efficient energy usage with full future-proofed performance. The IP54 and IP08 rating ensures durability in all weather conditions. Along with utilising the Ohme app, you can also seamlessly integrate this charger into your solar power - now that’s bright 💡
Zappi ⚡
Highlighting their commitment to the environment, Zappi (designed by MyEnergi) focuses on renewable energy with their products. Unlike some brands that boast using some solar, Zappi is designed to use 100% green energy from sources such as solar and wind generation. All Zappi products are ideal for both domestic and commercial use.
The Zappi GLO (ZAPPI-3AS07T-G) is a single phase 7kW charger with a tethered 6.5m Type 2 cable, encased in a sleek IP65 and IK10 polycarbonate housing for the ultimate protection against the elements. It offers dynamic load balancing and RFID tap-to-charge access, along with WiFi and Bluetooth interfaces for smart connectivity within the MyEnergi app 🤳🏻
If that isn’t green enough for you, the MyEnergi Zappi charger (ZAPPI-2H07TB-G) features ECO, ECO+ and FAST charging modes to support both standard grid charging and intelligent charging. Like the GLO charger, it is rated IP65 and IK10 with an integrated graphical backlit LCD, multicolour LED status indication, and built-in WiFi and Ethernet. The charger also supports OCPP 1.6J; an open-standard communication protocol to connect EV chargers to central power management systems 🔌
Rolec ☀️
Established in 1988, Rolec manufactures EV chargers with the goal of offering smart yet rapid charging points. The product range from Rolec is unbeatable, with an expansive range of OCPP (Open Charge Point Protocol) compliant chargers tailored for all uses - home, workplaces, commercial, fleet, and even development charging. Over 400,000 charge points have been manufactured and installed as of 2021.
Although the design is simple, don’t be fooled - the EVO range from Rolec is small but mighty. Available in 7.4kW (ROLEC5011) and 22kW (ROLEC5013), these chargers are IP54 and IK10 rated for true toughness. These chargers even have smart scheduling, remote monitoring, and tariff-aware charging, all of which are handled through the free Rolec EVO app 📲
Every EV charger in our product range has been tested to UK Smart Charge regulations, and comes with a manufacturer-dependent warranty.
Drive - or dive - into the world of electric charging today ⚡
In 2026, more UK homeowners are exploring solar PV, battery storage, EV charging and low carbon heating to reduce energy bills and cut emissions. However, the best results come from understanding how you use electricity day to day - powering your home with renewables starts with crystal clear information and a solid understanding of what you’re dealing with.
Want to find out more on choosing the sustainable path? Read our blog on Green2Go today.
With more and more UK drivers switching to electric vehicles, EV charging has become a growing necessity for both commercial and domestic use. At Electrical2Go we stock every type of EV charger you could need, from sleek 7kW home units to powerful commercial pedestals and smart solar-compatible chargers, all from leading brands at electrifying prices.
Dear Experts
I'm Newbie.
I have some plants installed Roofsolar System Sungrow, Huawei Inverter with Their Logger.
The logger Run Zero-export mode normally.
Now we have thirdty-SCADA Center, we want to monitoring adn control the limited power from remotely by connect to logger via Modbus TCP.
Can I do that?
Please see attached pictures.
Many thank
Working on a Vulcan oven with this controller
Oven starts and heats normally from cold but after running for a while temperature starts overshooting setpoint by around 35- 40 degrees before cycling back down. Temp probe resistance checks out and wiring and connectors all look clean. Relays are still switching, display readings seem stable and incoming voltage is good.
Anyone able to offer an electricians mate job in or around Warwickshire. I have passed my level 2 and have started level 3 training...two nights per week. I have a full and clean driving licence and have my own car, I'm 21 years old. I really need increased practical hands on experience to go alongside my increasing theoretical knowledge. I have worked on building sites and helped instal solar panels so I'm happy working at height. Any help or advice would be really appreciated
I have had a LEDIT-B100 module for less than two years and yesterday after I dimmed the lights down the lights flashed and it stopped working.
I have opened it and there are no burning signs. I have contacted the seller for a replacement but I am wondering if this is something common?
We are looking for an experienced self-employed electrician for ongoing subcontract work across commercial, agricultural and domestic projects in the North East.
We specialise in agricultural electrical installations — grain driers, poultry sheds, milking parlours — alongside general commercial work, domestic projects and heating control wiring including heat pump and solar PV systems.
Experience in agricultural or industrial electrical environments would be a real advantage, though not essential if you’re a solid all-round electrician comfortable across different sectors.
You’ll need:
• Minimum 3 years commercial experience
• ECS gold card or equivalent
• Own tools and transport
• CIS registered
• Part P qualified
• Happy working on farms and rural sites
We offer:
• Varied work across multiple sectors
• Prompt payment
• A growing business with fully employed positions planned in the next 6-12 months
Equinox Contracts Ltd are looking for a reliable electrician’s mate for ongoing subcontract work across commercial, agricultural and domestic projects in the North East.
You’ll be working alongside qualified electricians on a variety of sites including farms, commercial premises and domestic properties — supporting with cable pulling, first fix, containment, trenching and general site labouring.
You’ll need:
• Previous experience working with an electrician preferred but not essential for the right person
• Own transport essential — rural sites involved
• Physically fit and happy with outdoor and farm environments
• Reliable, punctual and a good work ethic
• CSCS card preferred
We offer:
• Varied work across interesting projects
Quick payment
• Outdoor and rural working environment
• Potential for full time position in the next 6-12 months
I’m an electrician specialising in inspection and testing (EIC, EICR, PAT, fault finding) and small remedial work. I’m looking for a partner in Colchester or the surrounding area to take on larger jobs together.
You should be able to self‑certify notifiable work. I’m looking for an individual electrician, not a large company.
If you’re interested, send me an email. You can find the email address on my company page: EICR & PAT Electrician Colchester | Smart Projects Essex - https://mindrise.uk
I’m a 19-year-old aspiring electrician. I’ve passed my 18th Edition along with my other electrical qualifications. I’ve got my own car, a full set of tools, and a clean UK driving licence. I’m currently finishing my testing qualifications and will then be starting my NVQ Level 3 and AM2. I’m reliable and keen to start working as an electrical improver or mate. Im based in south london
