Feb 17, 2013
1,529
233
638
England
Retired Electrician
Hi 2nd attempt writing this! As some of know wiring new house for family member. After great discussion / debate on another thread re those damn extractor fans with timers etc. I've decided to go with wall mounted 1g light switch outside each en suite (customers request as doesn't like pull switches) and the 3 pole isolation switch at low level 450mm as opposed to high level or above the door. Will that comply with BS7671 Regs? I'm going to use a fan whereby the manufacture will not insist on a 3amp fuse.
I'd already chopped in a deep box for a shaver point in 1 en suite at face height when the penny dropped that I had in fact installed it too high. I have now installed it at no higher than 1200mm. I take it height restrictions includes shaver points also.
Now for wall mounted TV points. Many wall mounted TV points to be installed, like a damn hotel! I've installed the boxes so as no higher than 1200mm. I would like to mount them a bit higher really so as to hide the boxes behind the wall mounted TV when installed. Your thoughts,experience appreciated.
We put fan isolator above door or in loft and never had any issues with bc etc
Just being devils advocate here. How would a maintenance guy or indeed another electrician that didn't do original job know that an isolation switch was up in the loft? should it be easily visable, accessible
Family member or customer?
As for where to put accessories.............the section on the eic says " deviations from 7671" or something like that.
Put them where you want.......
As for where to put accessories.............the section on the eicr says " deviations from 7671" or something like that.
Yes Family...family member doesn't want pull switches although I did say customer, well spotted though lol. As it's a new build, should there be any deviations?
Loft seems a daft place for one.
Next to an inline fan? Are you serious?
The fan is in the loft so why not?
Does anyone even fit the fans on the ceiling now?
As you're doing a new install, no, no deviations from BS7671, but then this is building regs (part M). As the iso is for servicing (in theory) then mount above door, otherwise we'll be mounting extractor fans between 450 and 1200 as well!
Reactions: 5 people
BS7671 doesn't actually cover the heights of accessories, that's all in the building regs. So it wouldn't be a deviation.
Reactions: 2 people
Thanks for reply.....If mounted higher, i was going to install them so as to reach them standing on the floor (no steps) The idea of fitting them lower (skt height) so as to be less obstructive.
fans will be ceiling type not in line
Just because it's a newbuilds doesn't exclude it from any deviations........customers have their own idea of what they want and sometimes that conflicts with the regs.....
As for not wanting pull switches, why not go with sensors, saves kids leaving the bathroom lights on.
Fan iso switch in loft, seen it many times.....lazy option but you can't count for customers not wanting trunk or after install plastering.
How is it lazy? The idea behind it is for maintenance.
What is the point in having one at all if your not going to have one local to the fan?
The whole job sounds like a right balls up to be honest, no planning and no idea of building or electrical regs, back to the drawing board I reckon, rethink the whole project again, Design is as important as the actual work being carried out.
Reactions: 3 people
Appreciate what your saying, but where do we draw the line to what customer wants and what the regs say we must do to comply BS7671 and or Building Regs.
well all a electricians work has to comply with BS7671. If the customer in this instance wishes to argue with LABC over the height of accessories that's their problem but it may not get signed off if it doesn't comply.
Ok, why is it a balls up. It's a one off job. I'd like to do it as best as i can, hence why i'm asking here. As you can see there are always different ways of doing things. i didn't want a load of electrical accessories outside the en suite doors as they would be on full view from the bedroom.
fair point and yes I wasn't thinking of online units.............i am however thinking of another cider and I'd be happy to buy you one spankey
for having intimated your lazy.
England
Retired Electrician
fixing heights domestic
Domestic Electrician Forum
driverman,
driverman,
