- Reaction score
- 17,076
i should have binned it.... but hey, it came in handy.Thanks for taking the time to take pictures, that's kind of you.
Discuss Customer wants round back boxes and round sockets, round everything! in the UK Electrical Forum area at ElectriciansForums.net
Rewire I am doing at the moment has a variety of these switches going in (no sockets, though, they will be mostly out of sight and something we are more used to).My customer wants to fit round sockets and switches. He has sent me a link to the back boxes that are required.
A few questions..
1. Has anyone fitted these before (see links below)? if so, did the backboxes take much longer than normal 25mm boxes? I believe they are 46mm deep or even 66mm??!! Do they need cementing in as I don't think they have screw holes? They look like a pain! No variable lug on one side, so has to be fitted perfectly level!!
2. The sockets will be unswitched. I can't see a problem with this as Table J1 in OSG shows a plug and socket as acceptable for isolation (and even functional switching) but thought I'd check?
3. Any other unforeseen problems using this style of socket/switch and backbox?
Backbox Kaiser back box for solid walls - Swtch - https://www.swtch.co.uk/product/kaiser-backbox-solid-wall/
Dimmer Duroplast Dimmer Round - Swtch - https://www.swtch.co.uk/product/duroplast-led-dimmer-round-switch/#what-you-need-to-know
Socket Roo Nigra Socket - Swtch - https://www.swtch.co.uk/product/katypaty-roo-nigra-socket/?attribute_pa_finish=black-matt&attribute_pa_function=single-unswitched
SwitchBakelite Rotary Round - Swtch
A faithful re-invention of the rotary switch common in Europe in the 1910s and 20s, made from that much-loved, classic material of the era: Bakelite. Thiswww.swtch.co.uk
What a PITA . Still, you charge accordingly
As Wolf points out, with European fittings the mounting screws go through slots that form arcs of a circle, so that the fitting can rotate exactly about its centre before tightening. UK fittings can't have slots because the screws have traditionally been exposed. European fittings normally have the screws and flange concealed behind a snap-on bezel or full-width switch rocker. Like many aspects of electrical materials, different conventions have evolved in different locations to achieve the same general result.
Switches have always been optional on BS1363 sockets but in the UK we're quite attached to them, unlike much of the rest of the world. FWIW Denmark also quite likes switched sockets.
Good to hear!Rewire I am doing at the moment has a variety of these switches going in (no sockets, though, they will be mostly out of sight and something we are more used to).
Yes, in solid walls the "joining" plates are a bit fiddly to get right, but you can push the boxes together to create multiples:3. Yes, the switches are very deep. Not much room behind them. Go with the deep boxes if you can.
Get customer to order everything they need & want, and set it all out beforehand. Some of the multi gang light switch stuff may end up going on metal flush boxes depending on setup, but any of the round stuff won't. The figure of 8 stuff is an absolute PITA to set the boxes for spacing.
So (asking as a layperson) what is your opinion on some electricians' objection to unswitched sockets because of the possibility of arcing? We hear this sometimes from installers who flat-out refuse to consider them.
Denmark are pretty quirky all round in terms of sockets. They officially allow installation of Type E and K but also C and F! They have the friendliest looking sockets though:
I personally do not like unswitched sockets. Why would you risk the arcing when someone plugs a high current appliance in, especially if they are a bit sluggish when inserting the plug.
So you would be happy to install them where it will be mostly low current appliances (lamps etc) but not above a kitchen worktop for example (kettle etc)?
Also, AFAIK the appliance has to be switched on for arcing to occur. So someone would have to hold down the switch of a kettle while slowly plugging it in or unplugging it. Is that correct?
Thank you for the really comprehensive and informative comment. I will save this and send it to any installer who says "unswitched sockets are not safe and/or illegal in the UK" - we've had a few of those over the years...At 13A, the switch is a nicety; it gets more important when you move up to 63 and 12A etc. but these are not relevant here. When you are used to switched sockets, relying on the socket contacts to break the load seems crude, but it works fine and most of the world does it. Even locales with highly evolved electrical regs that have historically used unswitched sockets have not found it worthwhile to introduce a requirement for a switch.
My laptop power supply always causes arcing when I plug it in anywhere.A laptop charger is as likely to make splash on inrush, as a heater on disconnection, neither is dangerous.
True, but there is also the aesthetic element to consider. Some of the designs we supply look much better with an unswitched socket (and in fact a couple of them are only available unswitched). For example the porcelain range the OP mentioned doesn't come as switched. I've been told by manufacturers that it's difficult enough to make a 13A BS1363 outlet cover in ceramic, let alone adding a switch!But I would say installing unswitched sockets for general use is inconvenient when switched ones are so widely available and standard.
Reply to Customer wants round back boxes and round sockets, round everything! in the UK Electrical Forum area at ElectriciansForums.net
