It is not how I would have did it but certainly not the worst i have seen and I cant really see anything that would break regulations to be honest. Seems to be the standard of work on rewires etc when prices are low.
A bit of intumescent sealant will fix the IP issue. But rest of the installation looks fine. Some people expect everything to be returned to it's original condition after a rewire. Get a decorator in man.
perhaps the installer didn't know or realise he had left a defective install, that's why I mentioned looking at the EIC.i was always told you can’t issue an installation certificate with defects
whisst a bit rough, if those cables are below the level of the plaster finish, you can plaster directly onto them when filling the chases.
if the plaster is that thin, which is unusual, that the cables are proud, then the chase should have been deeper, cutting into the brick by a few mm.. this would have required a chase cutter with the problem of dust. without seeing it in person, difficult to make a definitive assessment. from the pics., though, those chases should have been done with a chaser coupled to a vac. the coving should not have been damaged; room for cables behind. as said before, with those vertical chases, are there sockets directly below? if not, it's a major non-compliance. google "safe cable zones" to pull up a diagram
The plaster would cover just the cable but with the clips or the capping which is used in some areas for some reason it makes them flush with the surface of the plaster. As I say its more around the cost and what was expected for that cost. The customer has now got to get either major plaster works done and coving work or get cables channeled in further. Ive got the safe zones in the building regs and on site guide I hadnt even considered that and didnt get that far. Once I saw the install I was in complete shock if Im honest.
We are the borg the collective so any thing we say goes not always togeather. Lol. 1 person says one thing but others aren't so sure to agree. I
@pjmale45
It sounds like you had already made up your mind that the install was 'terrible' and you just wanted evevryone to say that so you had a bit of ammunition rather than advise.
What did the quotation say about chasing and making good afterwards? What's in the terms and conditions of the quotation? Has the invoice been paid and an EIC & Compliance Certificate been received?
Im very grateful for advise of course I was just surprised at the level of difference in peoples opinions on it. I do really think its a shame that this kind of workmanship is almost considered as 'standard'.
Im mostly industrial wiring as I install capital machinery into Blue Chip companies and I could never get away with anything near these standards but yes thats a very different field.
It is unfortunate that you are not entirely hearing what you expected to hear. Nobody has suggested this is anything other than poorly finished. When I carry out rewires I use a chasing machine with dust extraction, and all buried cables are installed in 20mm plastic conduit finished below plaster level, I also carry out plastering myself to at least as high a standard as a professional plasterer, all you'd need to do is decorate. I would agree that leaving supposedly buried cables proud of the surface finish is unacceptable. However I am certain you'd be paying more than 4.5K for my rewiring services. The points that are being made are that you have queried whether you have grounds for complaint with breaches of regulations, whilst you may, IMO those breaches are minor and not likely to result in the NICEIC asking for anything more than remedials to the possible IP issue on the top of the DB. You still have not answered my question on the vertical drops which has the potential to be a more serious breach of regulations. As far as finish goes you will need to review exactly what was quoted for before complaining.I had made my mind up yes that it was 'terrible' because it is. I will be honest and say that I had 'expected' most people to say it was because 'it is' lol. Its just not standards Ive ever come across in my history but admitidly I rarely see house re-wires any more. The advise is of course ammunition because Im not happy with the level of workmanship in retrospect to the cost involved. I wasnt sure on regs and this is where I required most advise tbh. I 'presumed' capping was a reg as Ive never ever seen cables not capped but as I say my experience in that is limited. I was also unsure on new regs on DB's. I thought cables had to be sealed into them as part of the fire side of things, never even knew about IP ratings.
Can I ask why you mention the NICEIC mate was the sparky a NICEIC paid up member?It is unfortunate that you are not entirely hearing what you expected to hear. Nobody has suggested this is anything other than poorly finished. When I carry out rewires I use a chasing machine with dust extraction, and all buried cables are installed in 20mm plastic conduit finished below plaster level, I also carry out plastering myself to at least as high a standard as a professional plasterer, all you'd need to do is decorate. I would agree that leaving supposedly buried cables proud of the surface finish is unacceptable. However I am certain you'd be paying more than 4.5K for my rewiring services. The points that are being made are that you have queried whether you have grounds for complaint with breaches of regulations, whilst you may, IMO those breaches are minor and not likely to result in the NICEIC asking for anything more than remedials to the possible IP issue on the top of the DB. You still have not answered my question on the vertical drops which has the potential to be a more serious breach of regulations. As far as finish goes you will need to review exactly what was quoted for before complaining.
