Dave-Titan
just got the call . . . . i passed C&G 2391 course!
did everyone find out today?
TL;DR
C&G 2391 course
3 tests after earth electrode test on TT installation - If that is Ze completed, then I got told in practical to carry out PFC after reconnecting earthing conductor.....EAWR say only do live testing if absolutely necessary so Zs could be calculated....that leaves other physical tests as RCD (TT install.) and functional tests. So PFC - RCD - Functional...Maybe !
Upvote 0
Legend of a man!
Thanks very much
Out of curiousity how did you grt hold of it?
Upvote 0
Legend of a man!
Thanks very much
It just manged to slip into my bag after the exam, i even showed it to the tutor in the bar after the exam, he wasnt bothered and said C and G would miss the odd paper. happy days, shame i could nt get it before the exam lol :17:
Upvote 0
id look at question 16 again with regard to the supply= need a live supply not to isolate
You would isolate the consumer unit at the main switch and test between line in and earthing conductor disconnected
You do not want power present when carrying out a Ze, as for Ze you have to remove the earthing conductor from the bar, so in theory people could be in the building using equipment that has no means of earthing if you left the board live like you insinuated
Upvote 0
How many marks can you drop to pass this per section does anyone know ? I forgot to say after the checks on the swa feeding the light how i would check ie pull on conductors to see if they are tight mechanically etc sense of touch
is the mark a comb of both sections ?
Upvote 0
Unsure to be honest this exam is a strange one when it comes to marking, its called a floating mark and the pass rate is determined by how hard they thought the exam to be
For example they mark all the papers and 80% of people pass, they then drop the pass rate to an amount they thinks best and results in lots of people failing, i think its unfair
I downloaded the paper from the member on the previous page and ive analysed my answers against bs7671 and gn3
My approx percentage is 79% - 87%
Upvote 0
read question 16 again, it says about the supply not the installation... i could be wrong so excuse if im off on 1
Upvote 0
i would also point out that in part c of Q .16 , i would say reinstate earthing conductor and not subtract test leads resistance .... could be wrong but excuse me if im off on 1
Upvote 0
Definatly reconnect earthing conductor for C)
Well reason i state that is when i carried out a Ze on my practical test, we had to isolate the supply and test from the mains in side of the main switch, to earthing conductor disconencted
Upvote 0
yeah thats fine but you using earth loop impedance tester and that requires a supply... tricky enough ,,,, maybe somone will jump in and clear this up, put me out of my misery then that will be 1 i would of got wrong haha
Upvote 0
Dave-Titan,
Hristo99,
Electrical Courses
