Dave-Titan
just got the call . . . . i passed C&G 2391 course!
did everyone find out today?
TL;DR
C&G 2391 course
I suppose if you want to learn and your taught well in the classroom most things are possible.
agreed. There is no substitute for experience but a willingness to learn is essential both in the classroom and out on the job. Experience will come with time.
At least that is what I told myself after I scewed up my 2395 last night :(
Upvote 0
Sorry to here that, why choose the 2394/5 over the 2391 out of intrest?
Upvote 0
thanks. I might just be being pessimistic but I made quite a few stupid mistakes like not reading the question properly. Even more frustrating because I found the practical fairly straightforward and got 95% in the multi-choice exam (and that was with one question that did not have the correct answer listed!) so I expected to do better.
anyway. 2395 because the college was pushing the new exams to be honest. I have to admit it might have been better to go with 2391 as there was very little info from C&G and so the course was pretty much a 2391 course but with 2395 exams. It was a bit distracting revising on 2391 papers and having to remember 2395 is periodics only.
I'm not doing 2394. I can't see the need for the domestic stuff I do, particularly as we have covered all the stuff on our course anyway.
Upvote 0
I'm booked in for the 2391 in may/june as I didnt want to get lumbered with the 2394/5 cost, I think I'll be ok on the written more worried about nerves on the practical.
Upvote 0
I know what you mean about nerves, I always get nervous when someone is looking at what I am doing and tend to cock it up and forget things.
Use your own instrument in the exam if you can and practice beforehand and I am sure you will be fine. The key is to be able to do it quickly as time is short but there is time to correct mistakes and still finish on time if you just crack on and don't panic.
Things to remember are:
- Remove parallel paths when doing bonding checks. I had a o/c main bond which looked ok with supplimentary bonding in place.
- make sure you test the motor circuit all the way through. I had a low IR (I think) on the contactor to socket section.
- check Zs values against Max Zs, not forgetting the 0.8 factor and careful of the MCB types.
- fill in as much of the cert as possible 1st and ask questions if you think there is something missing or you don't understand about the installation.
- careful of the safety stuff. You can mess up testing as long as it isn't safety related and still get away with repeating it.
I am assuming the 2391 practical is the same as the 2395 I did of course.....
Upvote 0
Multiple choice in the 2395 ...............:whatchutalkingabout
Upvote 0
I'd always thought of the 2391 or equiv to be the thing you work towards kind off the pinnacle of your installation training - years exp and all that, but really anyone off the street can do it with a good teacher with a few days training and adding to that you havent picked up on the bad habbits of years on the job.
Upvote 0
Alex anyone can be trained to pass an exam really, I'm sure with enough tutoring I could very well pass a few medical based ones, the difference is when you have someone sitting on an operating table and someone passes you the scalpel, and say off you go son
The same with us, yes you can train someone to pass the 2395 but then put a meter in his/her hand and open up a 32 way TP+N 40 yr old panel with wires going to the ying-yang and say right son sort that lot out
Upvote 0
I passed the 2391 straight after finishing 2330. Didn't find it too bad but I've only worked to 17th edition
so didn't need to change a lifetimes habits i.e names of instruments etc. I think it helps if you have just finished college for the theory exam as you are used to revising and half the stuff you already know but you can find the practical a bit of a challenge. Having a lot of experince should make the practical easy but then you have to get back in the habit of studying and possibly changing a lifetimes habit with regards terminology, procedures etc.
I thought I would get it out of the way while it was all fresh.
Upvote 0
Unfortunatley true Malcolm but the fact remains they still have a 2391 after four days and i'm only prepairing now after 4 years (alright not the quickest person but im getting there!!!!) remember my tutor telling us in the first year that with lots of hard work we could get the 2391 after 3 years !!!, I honestley dont begrudge them but do feel there should be more stringent entry req...
Upvote 0
Alex that is a great point. Years ago I had to do my basic electrical training in stages and a set order, B and C then HNC and onto HND, and you could not do the higher without the lower.
The problem with the City and Guilds seem to be that there is no criteria for our type of exams. The 2392/2394 is looked at as a "feeder" into the 2391/2395, but in reality it isn't because they have been identified now as two separate entities, one is initial verification the over full testing and inspection.
So you really can't set a pre standard to them. I remember years ago when I did the 2400 when the 16th came in, you could not do that unless you had the 2391-001 as it was then, but I believe that is no longer the case, it is still recommended you have the 2391-10 before you do the 2391-20, and they give concessions that if you have you don't have to do the practical again, but if you didn't have the practical you can do it during the 2391-20/2396
Upvote 0
100% agree. But then it was the same when I did my degree. 3 years of learning and a nice bit of paper but it didn't tell me how to work in an engineering enviroment. I had to work that out on the job ;)
We really shouldn't loose sight of the fact training just gives an understanding of the theory. Doing it in practice (in any job) is the only real way of becoming properly competent. The difference between knowledge and experience!
But you need both and doing the training 1st then gaining the experience 2nd has got to be the best way. Imagine putting that 40yr old panel in front of someone who didn't even know the principles of inspection and test.....
Upvote 0
That 35% is an average pass mark compiled from the results of everyone who takes the exam. At my local college the pass rate is more like 80 - 90% but you must have a full course such as 2330, a regs course (2382) and sign a declaration to say you are an experienced electrician before they will let you enrol. The idea is that the 2391 doesn't teach you how to 'test' (you should know that already) but goes into some of the finer details such as 3 phase safe isolation, testing SELV installations, earth electrode testing, understanding results etc.
Upvote 0
Dave-Titan,
Hristo99,
Electrical Courses
