hey guys, 3 days and counting until i sit the dreaded.
just doing some revision and im stuck with a particular question so any help would be greatly appreciated.
here goes.....
an earth electrode resistance test has been carried out, and the following results were obtained: 128ohms, 120ohms and 134ohms. Determine the value of Ra to be recorded on the certificate. show all calculations.
thats what i thought when i said add them up, is it really that simple, knew id feel a --- n it would be simple when id asked it, but hey its better to ask n be correct than presume n fail
Have a look at GN3 page 49 and then back to us with your answer. Don't forget to show ALL calculations
edit: There must be more to this question because once you have got the answer, you would have to adjust the rods and take the measurements again, I suspect.
identify two specific items on a new pvc conduit and trunking installation which are to be inspected using the sense of touch, before the cables are installed, stating what is being checked for in each case?
This is the main Electrical Courses at ElectriciansForums.net.
Find local recommended electricians courses. Avoid training "company" scams. Always go view the training centre before booking any electrical courses.
