Dave-Titan
just got the call . . . . i passed C&G 2391 course!
did everyone find out today?
TL;DR
C&G 2391 course
check its suitably fixed,
and expansion and contraction have been allowed for.
doesnt really warrant the 6 marks available which is why im struggling, and beginning to wish id not forked out for it
Upvote 0
GN3 says it is inadvisable to accept readings that differ by more than 5%. I have to admit I was never sure did this mean 5% between smallest and largest value (so a range of about 7 Ohm in this case), or did this mean +/-5% from mean (so about 120 to 134 Ohm is OK in this case)? In an exam, I'd just quote the GN3 wording, but to do it for real and know what I should accept ...?
Upvote 0
You want to read what the questions asks, this is key for the 2391. I must admit 6 marks seems high but the questions ask for 2 items AND for what you are checking.
So from your answer above which is correct but for 6 marks probably too brief:
Apply pressure to the conduit/trunking to ensure that the fixings are strong enough to withstand the intended weight of cables and likely mechanical outside influences.
Check inside all couplings that there is sufficient physical space within the couplings to allow for the expansion and contraction of the conduit/trunking experienced under the expected ambient temperatures so as to prevent distortion and bowing of the containment.
This is probably too wordy for an exam answer but does have a description of what you are checking and why you are checking it.
Upvote 0
the question asks " using the sense of touch". i would say 1 answer is to tug at the trunking/conduit to ensure it's firmly fixed.
Upvote 0
The senses questions seem to be the easy ones with generic answers with a little common sense I hope I get 6 marks for something like that in my exam in July if you're struggling with this good luck with the rest of the paper
Upvote 0
you ask a genuine question n then get a reply like this, cheers mate.
im fairly confident with the rest of the paper this question just stumped me abit, but then after all the revision last night n questions etc i didnt know if i was coming or going by the end of it.
no need for the negativity though
Upvote 0
I did this exam tonight and my god I found it hard.
It was the new style paper and I'm praying to got that I pass!
There were questions thrown in about zones in a shower room etc which I knew nothing about.
How did you find the exam?
Upvote 0
Was an interesting evening with the new assessment.
Questions seemed very BS 7671 in my opinion, far more than you usually get.
The national pass rate should go up a bit with this one.
Upvote 0
I was thinking that the questions seem easer than the other test papers i tried or was that i just done a lot of homework
Upvote 0
Dave-Titan,
Hristo99,
Electrical Courses
