Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
GN3 says it is inadvisable to accept readings that differ by more than 5%. I have to admit I was never sure did this mean 5% between smallest and largest value (so a range of about 7 Ohm in this case), or did this mean +/-5% from mean (so about 120 to 134 Ohm is OK in this case)? In an exam, I'd just quote the GN3 wording, but to do it for real and know what I should accept ...?
You want to read what the questions asks, this is key for the 2391. I must admit 6 marks seems high but the questions ask for 2 items AND for what you are checking.
So from your answer above which is correct but for 6 marks probably too brief:
Apply pressure to the conduit/trunking to ensure that the fixings are strong enough to withstand the intended weight of cables and likely mechanical outside influences.
Check inside all couplings that there is sufficient physical space within the couplings to allow for the expansion and contraction of the conduit/trunking experienced under the expected ambient temperatures so as to prevent distortion and bowing of the containment.
This is probably too wordy for an exam answer but does have a description of what you are checking and why you are checking it.
The senses questions seem to be the easy ones with generic answers with a little common sense I hope I get 6 marks for something like that in my exam in July if you're struggling with this good luck with the rest of the paper
you ask a genuine question n then get a reply like this, cheers mate.
im fairly confident with the rest of the paper this question just stumped me abit, but then after all the revision last night n questions etc i didnt know if i was coming or going by the end of it.
This is the main Electrical Courses at ElectriciansForums.net.
Find local recommended electricians courses. Avoid training "company" scams. Always go view the training centre before booking any electrical courses.
