Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
It was always recommended by the college tutors on completion of apprenticeship to get some experience of testing out in the field before undertaking the 2391.
Sadly those days have gone with all training being " fast-tracked" now.
As has been stated above if you use the wrong terminology you will lose marks but one point which has not been made is re the symbols in common use.
What I was told by my lecturer was if, for example you're talking about insulation resistance test, you put XXXM then the ohm symbol that's not technically right as you have not explained yourself. What you need to do is write --- Megohms them in brackets (M them the ohm symbol)
That way you have explained what you mean by the use of the abbreviation in the rest of the paper
Sorry I don't know how to get the symbol but hopefully this makes sense
well, for a start, and this is basic. with industrial, most installation is surface... tray, trunking, conduit. more technical as regards design. the main criteria is functional rather than aesthetic, and robust equipment, whereas domestic work is more aesthetic with lower loadings, sure you can think of more.
This is the main Electrical Courses at ElectriciansForums.net.
Find local recommended electricians courses. Avoid training "company" scams. Always go view the training centre before booking any electrical courses.
